Strange start after MD spacer install?
Old Sep 8, 2006 | 02:07 PM
Sumlime311's Avatar
After I installed my 1/2in MD spacer, I started the car and the RPMs went up like normal, but then droped really low like it wanted to stall out but didnt .
So I went under the hood and everything sounded normal, but I checked everything again and there are no problems (i think). Anyone else have anything like this?
Old Sep 8, 2006 | 02:13 PM
glennp_1999's Avatar
That is normal it will also happen if you take out the spacer. Reset the ECU to erase the memory and let it learn the new settings.
Sumlime311's Avatar
should i reset with the pedal method or the 12 hour batter dissconect?
Old Sep 8, 2006 | 02:21 PM
Either way it's the same thing.
abcquackyxyz's Avatar
either one...pedal is quicker.
Old Sep 8, 2006 | 02:24 PM
Sumlime311's Avatar
Great, I will reset it, take a nice drive and see what happens
Old Sep 8, 2006 | 02:38 PM
g35rcr's Avatar
make sure you dont have any leaks as well
Old Sep 8, 2006 | 03:07 PM
TheKnite's Avatar
I experienced the same rpm drops after I put in my K&N drop in filter. The RPMs would dip here and there when I would let go of the gas even during driving. Well I never reset the ECU, but a lot of people said the computer will learn by itself. I finally got fed up after many months, I put back the stock air filter and went to the dealer. Once the dealer noticed the issue, they performed "idle relearn" and the car is now back as it should be.
chinee
Jun 10, 2024 07:48 PM
jsimonk
Dec 22, 2023 03:49 PM
JMSABO
Aug 4, 2015 11:58 AM
EnCr1pt3d
Jul 29, 2015 03:35 AM
