Can u hear ur valves clicking at idle?
Old Sep 11, 2006 | 06:11 AM
Jining's Avatar
Hello, i have noticed that if I listen carefully I can hear my valves making a clicking noise when im idling, does this just mean i need a valve adjustment?
Old Sep 11, 2006 | 08:22 AM
Baluchitherium4's Avatar
My 06' makes a little valve train noise and it only has 4900 miles on it. I'm not sure if it's the valves making a little noise or injectors causing it. I can only hear it when I'm pulling it in the garage where the noise reflects off the walls.
Old Sep 11, 2006 | 09:12 AM
n2fooz's Avatar
Check your oil. Find the check your oil thread on here just in case.
Old Sep 11, 2006 | 10:17 AM
logik05se's Avatar
vq's are known for this...nothing wrong with it.
Old Sep 11, 2006 | 10:50 PM
maj83's Avatar
lazy a$$
You're not driving it hard enough?
Old Sep 11, 2006 | 11:35 PM
Andy2434's Avatar
Originally Posted by n2fooz
Check your oil.
+1 . . . I do not think that an engine valve train noise should be considered normal, if that is what you are hearing.
Old Sep 12, 2006 | 01:35 AM
Derek173's Avatar
Are you running mobile 1?
Old Sep 12, 2006 | 01:42 AM
2006_G_coupe's Avatar
Just take it to the dealer so that they can troubleshoot.!!
Does the car still have warantty?
Old Sep 12, 2006 | 01:45 AM
Jining's Avatar
yea it does but do you think they would do anything?
Old Sep 12, 2006 | 01:46 AM
Jining's Avatar
no im running synthetic the dealer put in, some weird brand i never heard of.... but its always used that
Old Sep 12, 2006 | 01:47 AM
Andy2434's Avatar
If the noise that you are hearing is indeed a engine valve train noise . . . They may check your engine oil level and opt to perform an engine oil consumption test.
Old Sep 12, 2006 | 01:48 AM
gary c's Avatar
Start here.............
Check your oil, I know it's a PIA with this dip-stick.
I use Mobil 1 and don't have the valve noise your
talking about. My noises come from intake/exhaust.
Old Sep 12, 2006 | 01:53 AM
Jining's Avatar
the oil is kendall gt-1 blend, Just had the oil changed 3 days ago so i dont think its the oil level, since it did this before the change as well. Ill try the first gear thing. Thanks a lot!
