How do people think our pedals are for heal-toe?
Old Sep 14, 2006 | 12:29 AM
logik05se's Avatar
Seriosly i was never actually too great at this, but i got the point and i could pull it off decently in past cars. So tell me...is it just me, or are these pedals completly terrible for heal-toeing? I think its because the brake is higher then the gas pedal, as well as there a little to far apart. what does everyone think?
Old Sep 14, 2006 | 12:31 AM
God|ZIlla168's Avatar
to do a proper heal toe you need to readjust the brake pedal. Normal car set up is not the best way.
Old Sep 14, 2006 | 02:05 AM
pch2005's Avatar
i do it all the time. i think they are set up pretty good. i have tried it in my brother's 350z and it is a little bit more difficult.
Old Sep 14, 2006 | 02:20 AM
accordfreak's Avatar
feels natural to toe heel in this car.. I don't know how you people heel toe though...
Old Sep 14, 2006 | 02:30 AM
jclit's Avatar
When you barley start heel and toeing in the G, you seem to give it more break then necessary.
Old Sep 14, 2006 | 02:31 AM
pch2005's Avatar
that for sure.
Old Sep 14, 2006 | 02:34 AM
bull3t's Avatar
it's alot easier to do with my razo cf pedals...you could also adjust them so they're really close to each other but i like them like they are in the pic...
Attached Thumbnails How do people think our pedals are for heal-toe?-new-pictures8888888888-004.jpg
anDross's Avatar
This car is really easy to heal toe in. No adjustment is needed to do it properly. Maybe it's because of how you're doing it? But my buddy (ColdFusion) and I can heal toe our cars fairly naturally.
Old Sep 14, 2006 | 02:35 AM
anDross's Avatar
Well it's probably cuz i've been heal toeing for 3-4 years now lol?
Old Sep 14, 2006 | 02:36 AM
anDross's Avatar
With my previous car too I mean...
Old Sep 14, 2006 | 08:02 AM
FAST1's Avatar
Maybe you aren't doing it correctly. "Heel-and-toe" is a misnomer. It actually involves the ball of your foot and the side of your foot. Sure the brake pedal is higher than the throttle pedal when not braking, but you'll find that when braking, the pedal will travel down to be nearly side by side with the throttle pedal. Here's a step by step description of how it should be done:
1. Begin braking for the corner with your right foot. The location of the pedals and the size of your foot will dictate where you position your foot on the pedal, but most likely it should be canted a little to the right, closer to the throttle pedal.
2. Push in the clutch with your left foot.
3. This is the hard part. With your right foot still applying pressure to the brakes, roll the outside edge of your foot outward and downward to touch the throttle pedal. Use the outside of your right foot to blip the throttle.
4. Release the clutch with your left foot.
Practice heel and toe when you car is parked so that you get accustomed to the correct position. I find the position of the brake and throttle pedals on my G35 coupe to be ideal for heel and toe. After some practice it will become second nature to you, and you'll do it without thinking. Some think that heel and toe is used just for racing, but actually it's used to execute smooth downshifts and to reduce wear and tear on your tranny.
Old Sep 14, 2006 | 10:32 AM
glennp_1999's Avatar
If you have a small foot then it's a terrible car to do heel and toe. Just change the pedal pads with some aftermarket pads. The one that has a picture above is a good example this will make heel and toe a little easier to do.
Old Sep 14, 2006 | 10:47 AM
Mountian Pirate's Avatar
Wearing 12's heal and toe are a part of life..
Old Sep 14, 2006 | 11:27 AM
logik05se's Avatar
lol well it seems it isnt the car....only other thing i can think of is because im always wearing dress shoes going to and coming from work so i guess thats got alot to do with it. And of course like i said, im no expert.
thanks for the feedback.
Old Sep 14, 2006 | 12:00 PM
jinubob81's Avatar
Evil Bastard
to heal toe, you should go to a doctor, preferably a podiatrist. Hell, maybe a bandaid and some advil will fix most things.
To HEEL-TOE, follow the above directions. There is also another method, but the above is the most often used.
