VDC Bypass
Old Oct 20, 2003 | 01:22 PM
uvalax14's Avatar
VDC Bypass
So we have figured the VDC always has power to it since the default setting is on...so if you set up a bypass switch that can flip the power on/off then you can remote mount it easier than trying to relocate the VDC switch, anyone try this yet?
Old Oct 20, 2003 | 07:12 PM
ChrisG35C's Avatar
Re: VDC Bypass
Fiddler's kit is one of the best mods that I've done so far !
It was extremely easy to install with the step by step illustrated instructions and I've had it for over a month and it works flawlessly. It is so nice to just get in the car and drive without having to remember to turn off that damn VDC. I like the "bad weather" switch that disables the device putting everything back to stock. I will have to turn on that switch very soon as the winter months are coming !
Old Oct 20, 2003 | 09:04 PM
uvalax14's Avatar
Re: VDC Bypass
why spend 80 bucks for what essentially a bypass switch does the same for at 1buck??? if you cut the power supply off to the switch then it does the same and u can run 2 wires to hook it up
Old Oct 20, 2003 | 09:09 PM
redwillow's Avatar
20 Year Member
Re: VDC Bypass
have you actually installed the switch or just thinking about it?
i'm wondering if actually cutting the power to the VDC switch stops the VDC from coming on at ignition....or would it still default to VDC on... just stop the switch from working.
03 6MT coupe, red/willow, premium, aero, splash guards, alum pedals, clear corners, 15% tint
Old Oct 20, 2003 | 09:25 PM
ChrisG35C's Avatar
Re: VDC Bypass
I sincerely doubt its that simple.... Regarding my Fiddler VDC bypass box, I mounted it under the dash on the drivers side. There is a spot there that suits it perfectly. It fits between a metal frame and the plastic under dash panel. I used a small piece if velcro to hold it in place. I can easily access the over-ride switch as well.
Old Oct 21, 2003 | 04:10 PM
shodog's Avatar
Re: VDC Bypass
It seems like a lot of work to bypass something that only requires a simple push to disable. It's part of my start up proceedure. Start the car, push the vdc button, turn the stereo on, buckle up and go.
Jim
'03 Sedan
Brilliant Silver/Graphite
6MT/ Premium package
Sport tuned suspension
Aerodynamic Body Kit
Navigation and Satellite Radio
Old Oct 21, 2003 | 10:10 PM
ryoken's Avatar
Re: VDC Bypass
I prefer to leave it on unless I'm driving aggressively. You never know what other drivers are going to do, and I find that my reactions in panic situations aren't always as smart as my reactions when driving aggressively. Plus, my wife occassionally drives the car, so it's better if it defaults to on, since it may save her and my kids someday (and maybe as a side bonus, the car too).
That way, the system is only off when I want it off, and it's never off when I've simply forgotten about it.
06g35
Feb 14, 2022 05:59 AM
MThawkins86
Oct 24, 2015 02:07 AM
hrdwirk1
Oct 2, 2015 06:34 PM
markbilo
Sep 30, 2015 01:33 AM
