splash guard isstallation?
Old Oct 23, 2003 | 09:47 PM
aenokea's Avatar
Hi all. I was wondering if anyone here installed the splash guards. I just ordered a set at Grubbs and wanted to install them myself. Anyone have any pointers or tips for the install? Any help would be appreciated. Thanks!
Old Oct 24, 2003 | 12:15 AM
TXSilver6MT's Avatar
Re: splash guard isstallation?
Hi there. I bought my splash guards from Grubbs too and installed them last week. They are very easy to install but you do have to remove each wheel to get the drill in there to make the required holes. You might be able to get away with only removing the back wheels if you have a right angle drill.
Good luck!
Old Oct 24, 2003 | 12:17 AM
BW5_Coupe's Avatar
I installed the splash guards a couple of weeks ago. It's a pretty simple job. They come with instructions which clearly show you what to do. They call out metric drill sizes, but you can use English equivalents. The biggest hassle is that you need to remove the rear wheels to install the rear guards. Only other recommendation is to make sure you clean the mounting surfaces (per instructions) adequately to optimize bonding of the double-backed tape. Good luck!
2004 G35C 6mt, TB/Willow, Premium, Nav, Aero, Sirius
Old Oct 24, 2003 | 12:52 PM
Grifter's Avatar
I had to remove the rear wheels in order to get to the drill spots. The front wheels weren't an issue, just turn them all the way to the right/left. I also cleaned the surface with 50-50 alchohol-water solution and still couldn't get the double sided tape to take for more than 5 minutes - even with steady pressure. I don't think the amount of tape they use is enough. Maybe it was the humidity that day. Anyone else have this problem?
I'm going to have to remove them and see if I can get wider tape to re-apply. This time using more coverage.
Old Oct 24, 2003 | 07:59 PM
BW5_Coupe's Avatar
I didn't have any problem with the tape sticking. I first cleaned the area with Dawn/water, dried, then used the 50/50 alcohol solution. The taped grabbed and hasn't budged since.
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
Kelvin Style006
May 23, 2016 03:47 AM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
st33zygill
Jul 29, 2015 10:05 PM
laksjd84
Jul 24, 2015 05:12 PM
