need some help RE: amp&sub installation
Old Oct 23, 2006 | 03:53 AM
Flavius's Avatar
ok i have an 03 6spd coupe and i want to install a sub but keep the stock head unit...i have another aMp...and i was told that i can somehow add the amp i have to the amp that comes with the car anyone have any type of instructions or pics? any tips ? thanks this thread could probably exist but i don't have time to search through all those threads if anyone has the link to those threads then that'll help to thanx
Old Oct 23, 2006 | 05:04 AM
Jining's Avatar
well it definitely is possible, I have an amp with 2 subs w/ my stock bose system. I had it installed professionaly, but they have some sort of OEM harness type thing that wires into the original system.
Old Oct 23, 2006 | 08:45 AM
g35rcr's Avatar
you need an inline converter to tap the signal off the rear speakers, then you run power to your sub amp, run the rca from the converter to your sub amp and connect the sub to the amp with thick guage speaker wire. there is no oem harness, you want to spend some money on a good converter because you dont want one that gets all trash signal
Old Oct 23, 2006 | 10:17 AM
Dieselnuts's Avatar
I believe this is what your looking for. Want mine? Never been used
https://g35driver.com/forums/archived-sales/119537-fs-pac-oem1.html
Old Oct 23, 2006 | 10:38 PM
Flavius's Avatar
anyone else with any advice?
Old Oct 24, 2006 | 12:14 AM
DankStar's Avatar
Aftemarket goodies
If you want to add some amps but keep the OEM Deck look at using the JL system(CleanSweep CL441dsp). Please check this out I believe this is what you are looking for. Please let me know if this works for you.
Old Oct 24, 2006 | 01:44 AM
NorCalGRide's Avatar
Try this.
I'm waiting on my amp power wire kit in the mail to do exactly what the above thread talks about. I'm adding Infinity amp and 10" sub in the 4080 box. Good luck.
Old Oct 24, 2006 | 08:55 AM
dR6's Avatar
dR6
Here's my DIY:
https://g35driver.com/forums/showthread.php?t=101293
G-MAN (CANADA)
Canada
Sep 7, 2015 03:51 PM
3000vr4tt
Sep 7, 2015 12:48 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
