amsoil filter
Old Oct 30, 2006 | 11:47 PM
xx7sephiroth7xx's Avatar
G
amsoil filter
hey, i searched and searched but couldn't find the answer to my question:
For those amsoil dry filters air that can replace the stock air filter, is it one-time use only? is it at all better than the stock filter? where can i find one (i can't seem to find the size/part # for it either)?
thanks in advance
Old Oct 31, 2006 | 12:04 AM
Calvin's Avatar
Overglorified Altima
search harder
less than a minute, on the first page...
https://g35driver.com/forums/showthr...ghlight=amsoil
you also might wanna check the amsoil website next time..
"Cleaning
EaA filters should be cleaned every year or 25,000 miles, whichever comes first. Carefully remove the filter from the housing. Clean the housing with a shop towel, being careful not to knock contaminants into the air inlet. Filters can be cleaned by carefully vacuuming the filter media on the dirty side, or by holding the filter with one hand and carefully blowing the filter media at a 45 degree angle on the clean side using low-pressure shop air (15-20 lbs. psi).
Service Life
AMSOIL Ea Air Filters are guaranteed for four years or 100,000 miles, whichever comes first. The guarantee applies only if the filter has been serviced according to AMSOIL recommendations. In off-road, frequently dusty or other severe duty applications, clean and change more often as determined by operating conditions or as indicated by restriction gauge."
Old Oct 31, 2006 | 12:35 PM
fortified's Avatar
AEM makes a similar filter, but they only come in cone shapes. Good for aftermarket CAI's etc. They are washed out though, you don't use air.
Either one is an upgrade over a K&N IMO.
KruZZe
Feb 27, 2023 05:04 PM
f22raptor
Mar 18, 2016 08:50 AM
prinny
Nov 22, 2015 11:07 PM
vamarris
Sep 26, 2015 12:56 PM
