Cleaned the Mass Airflow Sensor....
Old Nov 8, 2006 | 08:59 PM
Nismo G's Avatar
Had a day off of work and school so i went to my dads shop and picked up some electrical contact cleaner (his company builds guages so they use the right stuff). Took the MAF sensor off to clean it (had soooo much built up dirt) and then put it back in...i just took it out for a spin and the throttle responce is so much better the car seems to pull harder as well.....
Figured i would give a little write up on it. I would say that this cleaning would be an easy way of gaining a few ponies.....
Old Nov 8, 2006 | 09:53 PM
V35 Skyline GT's Avatar
6MT Coupe
Hmmm...heard of doing this a long time ago.
Thanks for the reminder.
Curious though, how many miles did you have on your odo before cleaning yours?
Old Nov 8, 2006 | 10:06 PM
Nismo G's Avatar
76,xxx...haha i know alot of miles, it was filthy im going to take it to the track tomarrow night i already know im going to run better numbers.
Old Nov 8, 2006 | 10:15 PM
GreenGoblin's Avatar
The goblin resurrection
ya i am gonna clean mine only 37,xxx but might as well maybe get some better mpg
Old Nov 8, 2006 | 11:28 PM
nchima's Avatar
Probably a retarted ?
But I got an AEM Cold Air intake, is it the snesor connected to that.
Any pics that could point me in the right direction.
And were to get the stuff to clean it.
Old Nov 9, 2006 | 01:30 AM
chester's Avatar
yes
Old Nov 9, 2006 | 03:14 AM
SFG356MT's Avatar
It doesn't hurt to take a few minutes to clean it out at any mileage.
Old Nov 9, 2006 | 06:59 AM
chilibowl's Avatar
If you dont have cleaner handy, just wipe AROUND the actual sensor, then with a Q-tip and some rubbing alcohol, you can carefully clean the sensor. Be sure to not drench the Q-tip either...
Old Nov 9, 2006 | 10:51 AM
fortified's Avatar
Why would there be so much dirt building up on it? Have to wonder if you use an oiled filter like a K&N, if that might worsen the situation.
Old Nov 9, 2006 | 12:11 PM
sonywoofer's Avatar
Anyone got a DIY on this? How hard/easy is it to do? What tools needed?
Old Nov 9, 2006 | 12:31 PM
bobshuai's Avatar
sometimes isn't just dirty because if we use after market filter then we will spray the filter oil after we clean the filter. But sometimes oil can be over spray because there isn't any accurate amount that you can spray. Plus tiny loose dirty will pass the filter day by day and that is how you get dirty build up on the sensor. I found out this product at the sema show this year. The Brand is called CRC ( Mass Air Flow sensor cleaner ) and the web site is www.crcindustries.com.
Old Nov 9, 2006 | 12:46 PM
nchima's Avatar
any stuff I can get at the local automotive store
Old Nov 9, 2006 | 12:48 PM
bambam26's Avatar
https://g35driver.com/forums/intake-exhaust/105447-anyone-clean-their-maf-mass-air-flow-sensor.html
Old Nov 9, 2006 | 01:10 PM
6MT Coupe
Cool...thanks...haha...uhh yeah that's a lot of miles
Have fun at the track.
And thanks all for the other posts and info from everyone.
I know, I know...this is your thread, but really appreciate this reminder and need to make it one of my normal service to do's.
Wonder if this will help my A/F ratio. Running lean with my rev-up VQ per my dyno pulls. Or it's just the dreaded California emissioned tuned ECU.
Old Nov 9, 2006 | 02:42 PM
fortified's Avatar
Originally Posted by bobshuai
But sometimes oil can be over spray because there isn't any accurate amount that you can spray. Plus tiny loose dirty will pass the filter day by day and that is how you get dirty build up on the sensor.[/url].
One of the best reasons to use an Amsoil or AEM dry filter I've ever read. (I am a K&N veteran user, as in 'not any more').
It is fortunate the Nissan sensor is so easily cleaned compared with a lot of cars.
