Please Help! Photoshop Wizzes! How Do I...
Old Nov 10, 2006 | 07:36 PM
LightsOutG35's Avatar
Originally Posted by 6spG
You mean a dropshadow?
No, I want it to be in the avatar with NO background, nothing, all you see is the image and that is it.
Old Nov 10, 2006 | 07:37 PM
CrazyRuskie's Avatar
Well thats easy, when you create a new file in Adobe Photoshop, make the background transparent, then cut/paste that little guy into the image... make sure you trace around him to select just the guy
Here is what I am talking about. Look at "Texasscount" avatar. Thanks.
https://g35driver.com/forums/lounge-off-topic/124864-u-may-have-heard-but.html
rockd's Avatar
are you trying to create an image without a background?? if so, you can't do that with photoshop or jpeg/gif files (to my knowledge)
you can do that with PNG files... try Macromedia Fireworks
Old Nov 10, 2006 | 07:38 PM
Could you please post step by step directions? I am not the best with Photoshop. Thanks.
Old Nov 10, 2006 | 07:39 PM
rockd's Avatar
https://g35driver.com/forums/showthread.php?t=124864
I guess you can do that with gif files... try PNG anyways; it might be easier
Don't have PS on this computer, so I can't really go step by step for you, but generally when you create a blank file, it asks you to choose WHITE BACKGROUND or TRANSPARENT
Old Nov 10, 2006 | 07:44 PM
LjN_728's Avatar
I think you should ask Texasscout and this is what you'd get if you choose transparent background:
Can't you just put up a pic of a half naked girl? hehe
Attached Thumbnails Please Help! Photoshop Wizzes! How Do I...-untitled-1-copy.jpg
Old Nov 10, 2006 | 07:45 PM
This does not seem to work either. I traced out the image, created a new document and made it transparent, saved it as a JPEG, and put it as an avatar, and once again, the white background stayed? Am I doing something wrong?
Old Nov 10, 2006 | 10:55 PM
RawFusion's Avatar
Right click to save...
Takes 10 seconds to do: Open it in Photoshop, delete the white, save as a gif with transparency checked.
Old Nov 10, 2006 | 11:33 PM
Thanks for trying, however, this did not work either. Please try for youself or anyone eligible to have an avatar. You will see, the grayish background and square still remains. Anyone else?
Old Nov 11, 2006 | 12:14 AM
RawFusion's Avatar
Are you trying here? I thought you had to be a Premier Member to be able to add an avatar.
You have to remove the background and saved as either a gif or png (no jpegs) if you want a transparent background. If that doesn't work then the forum you're trying to add it to is changing the picture so no matter what anyone does to the picture it will not work.
[edit]Nevermind, after re-reading your first post, I don't understand what you want to do anyway so I'm probably wrong.[/edit]
Picture Share
Feb 4, 2018 12:41 PM
avalon96
Feb 20, 2004 04:03 AM
nuttyprof
Feb 2, 2004 03:07 PM
KDogInChiTown
Mar 30, 2003 09:14 AM
