Headlight Housing Removal (DIY)
Old Nov 16, 2006 | 08:28 PM
2006_G_coupe's Avatar
Thumbs up
Nice work.!! Im sure that this will help a lot of people.!!
Old Nov 16, 2006 | 09:15 PM
Daehtihs's Avatar
One of the best DIY I've seen. THANKS!!
Old Nov 16, 2006 | 10:17 PM
Infinite_R's Avatar
Yaaaah Yaah Trick!!
So this is good if I ever wanted to upgrade my 04 headlights to the 06 projectors or is that not possible? I'm curious?
Old Nov 16, 2006 | 11:07 PM
Queenskid24's Avatar
1 of the most detailed DIYs ive seen.
Old Nov 16, 2006 | 11:18 PM
Jee_35's Avatar
dang I ran into a problem, when I tried to take off my bumper, those 2 screws inside were actually the 10mm bolts, couldnt really manuever enough to even get them loose.. is there any tool that i can get to help me?
Old Nov 16, 2006 | 11:48 PM
redlude97's Avatar
They should be bolts with philips heads on the ends, at least on the 06 they were. If not, just get a universal joint so your ratchet can swivel or remove the entire fender liner
Old Nov 17, 2006 | 12:40 AM
Triji's Avatar
10mm bolt w/ a phillips X in the middle of them. A thin screwdriver is alot easier in that tight space unless you have a real long extension for the 10mm.
Old Nov 17, 2006 | 02:37 AM
imalazeeass's Avatar
you're the man!
Old Nov 17, 2006 | 08:10 AM
SilverII's Avatar
very nice and precise...thx
Old Nov 17, 2006 | 10:10 AM
Jee_35's Avatar
ah you're right,must have been blind.. :P
Old Nov 17, 2006 | 02:17 PM
watsgoodG's Avatar
wow great job even though my car is an 06 with those directions i think i would attemp to try it
Jusseth
Sep 13, 2020 12:25 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
Mick_L
Aug 25, 2015 04:27 PM
Frostbite91
Aug 20, 2015 07:20 PM
yassy
Aug 9, 2015 07:31 PM
