Tein Basics and Sways
Old Nov 18, 2006 | 07:19 PM
G35_sylvi's Avatar
I never knew how much of a BIZNOTCH it could be to install basics and sways. I started on my own around 3 and I still hvaen't been able to install my first one!!!! I noticed that the sways were just tedious but not too hard to do. Its the basics that I'm stuck on. I released the three nuts on top under the hood, and i took off the nut holding the sways. The only thing is, i can't take the stock coilover out! Its just stuck!!! Do i need to get a spring compressor?? WHAT SHOULD I DOOO!!!!!
Old Nov 18, 2006 | 07:22 PM
aleok's Avatar
read the DIY write-up about installing springs. is basically the same thing.
Old Nov 18, 2006 | 07:23 PM
ozracer01's Avatar
You're very lucky...i'm happy that you didn't hurt yourself in the process, although you could of seriously lost a finger or two. Whenever removing a shock or strut...you should always use a spring compressor. The reason its stuck is beacause the shock is compressed by the shock itself and more importantly the spring. They are avail. on rent from autozone, or advance auto parts, any auto part store really.
Old Nov 18, 2006 | 08:48 PM
MyLilBlkG's Avatar
go rent a spring compressor and use it. it'll make it so much easier.
prinny
Nov 22, 2015 11:07 PM
NyCrAzY
Oct 1, 2015 09:19 AM
Learned Hand
Oct 1, 2015 09:02 AM
joel extreme
SOCAL Meetings & Events
Sep 29, 2015 04:44 AM
