Throttle Body Experience
Old Nov 29, 2006 | 01:43 PM
bull3t's Avatar
Three weeks ago I noticed that when i came to a stop and pushed in my clutch the revs would rise up then fall almost to zero causing the car to
shudder/stumble...During a warm start up the car would almost die as well...I read that maybe it was a dirty maf...I cleaned the maf but it didnt
help...Tried doing a battery disconnet, that didn't help either...So i took it to a family friend who is a mechanic...He cleaned the throttle body for me with
throttle body cleaner...There was a lot of carbon buildup...He cleaned the throttle body while it was still on the car, he just removed my z-tube...I
started the car up and drove it around...The problem was solved...He told me that i should take it off at home and clean it better...So i went home
disconnected it and cleaned it really well...I started the car up and it was idling at 1k rpm!!! The check engine light also came on after i drove it around
a bit...I then tried all of the throttle body relearn procedures (i'm a professional at this now)...The idle relearn somewhat helped but it wouldn't
stick...I hate all this computer controlled crap...After a week I took it into the dealer...I thought it was gonna cost an arm and a leg, but luckily my car was
still under warranty...It took 1hr for them to recalibrate the ecu (normally $140) and my car was back to normal...Now my car runs better than when i
first got it...No more stumble/shudder...Alright so basically if your car is experiencing the same symptoms as mine was, clean the throttle body while
it's still on the car...Sorry for the long post
Old Nov 29, 2006 | 01:52 PM
g35rcr's Avatar
you touched the butterfly didnt you...you just need to do the idle reset and it will be fine...
Old Nov 29, 2006 | 01:57 PM
bull3t's Avatar
you have to touch it when you clean it...when my mechanic cleaned it while it was on the car and it was fine...i think the problem occured after i
disconnected the whole thing to clean it...
Old Nov 29, 2006 | 02:01 PM
g35rcr's Avatar
if you unplug your battery you can touch it...if its plugged in it will do what happened to yours and you can clean it without touching it if you take if off the plenum...the best way to clean it is to disconnect the battery, remove the tb, and clean both sides and around the butterfly
Old Nov 29, 2006 | 02:13 PM
bull3t's Avatar
i unplugged the battery and then took off the throttle body...sorry i forgot to mention that...it still happened...but this isn't about my car...my car is fixed
now...This is for those of you that have the symptoms i experienced before cleaning the throttle body...
Old Nov 29, 2006 | 05:31 PM
zazaracing's Avatar
Team Transport Member
Hey dude where did you find the reset/relearn steps it used to be on technosquare but its not anymore.
Old Nov 29, 2006 | 05:34 PM
bull3t's Avatar
it's on the motordyne website...download the manual and scroll down...you'll find it
Old Nov 29, 2006 | 06:29 PM
g35rcr's Avatar
mine acted like that then i checked my throttle body bolts and one was a loose
Old Nov 29, 2006 | 06:32 PM
zazaracing's Avatar
Thanks dude
Old Nov 29, 2006 | 07:10 PM
jinubob81's Avatar
Evil Bastard
nice post. I'll check and clean my throttlebody next time I take it out (maybe for a spacer or something).
Old Dec 11, 2006 | 02:38 PM
bambam26's Avatar
Alright maybe I am just dumb but you guys are crossing up everything so can i get someone to tell me what needs to be done to clean the throttle body. Correct me if I am wrong...
Disconnect the battery
Disconnect the TB clean both sides
Put it back on connect it back up
connect the battery and drive it.
Old Dec 11, 2006 | 02:57 PM
bull3t's Avatar
okay...you can do it like that but you might have to get it reset/recalibrated by the dealer because your ecu might get out of whack...
from my experience disconnect the battery...disconnect the intake tube...leave the TB on the car now you can see the TB butterfly...just spray
the TB cleaner in there and wipe away the dirty liquid...and do it a few times...you can move the butterfly while you clean it too...also do not
disconnect the TB wire...if your TB is dirty, after the cleaning, you'll notice a huge difference...and one more thing, if your computer does get
out of whack, do a 12hr battery disconnect...i spoke to 3 other members that had a problem with the idle after the cleaning (we all removed the TB from the
car when cleaning which probably caused it to get out of whack) and they did the 12hr battery disconnect which cured the problem...if that doesn't fix it
then your gonna have to take it to the dealer like i did...but trust me it's worth it...
Old Dec 11, 2006 | 03:29 PM
bambam26's Avatar
Thanks going to do it when I get home. i have really bad carbon build up on mine. I saw it when I put my Crawford on this weekend
Marlin84
Apr 1, 2020 12:52 PM
prinny
Nov 22, 2015 11:07 PM
dseet
Oct 11, 2015 12:40 AM
Usman Ali
Oct 4, 2015 08:23 PM
NyCrAzY
Oct 1, 2015 09:19 AM
