clearance strips leds and installation
Old Dec 4, 2006 | 10:46 PM
mubay's Avatar
guys, i need help for clearance strips and installation. i want to change my clearance lights and i need some suggestion for the bulbs fitment and installation for 04 coupe head light.
i'm planning to buy either 194 4led or 194 5led refractor or 194 6led, its all from
http://frickinbrite.com/catalog/index.php?cPath=40
I don't know which one gonna fit for 04 coupe clearance/strips. are they all fit for mine or i have to find another one? and are they plug n play or need additional resistor or something.
I found threads showed fog lights installation without pull out neither front bumper nor the wheel. Can i channge the clearance without pull out them too?
thank you,
Old Dec 4, 2006 | 10:53 PM
Calvin's Avatar
Overglorified Altima
i prefer vleds over superbrightleds...but that's jmho
"1. Turn your tires all the way so you can have the most room
2. Now look under your fender and find a few plastic bolts that can be easily push out by any screwdriver. Then look for several screws that have been placed somewhere along there.
3. Once you have taken all the bolts and screws off, carefully pull back the plastic walling so you have a clear visual on the back of the headlight. What your looking for is this black plastic stick-looking thing thats on the opposite side of your low beams. Hard to explain what your suppose to look for, cant really find a pic of it now, but youll notice it. it goes right where yoru clearance light is suppose to be
4. When you find it twist it and it should come loose and there you go, the bulb is placed at the end and all you do is just put the replacement bulb in and twist it back into place
5. Cover everything back up again, screws, bolts etc.
**if you need more clearance to work with, you can always jack up the car or move the tire if needed**"
hope this will help you
https://g35driver.com/forums/showthr...+light+install
Old Dec 4, 2006 | 11:07 PM
mubay's Avatar
does the leds from v-leds fit mine? i got the installation guide from that threads though, thanks.
Old Dec 4, 2006 | 11:09 PM
Calvin's Avatar
no problem
yes, vleds also has 194/168 bulbs
Old Dec 4, 2006 | 11:10 PM
chester's Avatar
Yea i just got some reverse bulbs from Vleds.com which i didn't like the hint of blue in it.. anyone want them? Pm me
Calvin's Avatar
^^i have those! i love em
Old Dec 4, 2006 | 11:14 PM
mubay's Avatar
what color are those? super white or super blue? price?
Old Dec 4, 2006 | 11:39 PM
Algy's Avatar
shoot ill buy them. but how the hell do you change the friggin bulbs for the back lights?!?!?!?!
Calvin's Avatar
they have a hint of blue to them
zoop425
Mar 29, 2016 05:51 PM
mdzukunft
Drivetrain
Aug 25, 2015 10:28 AM
Ashton35
Jul 22, 2015 09:19 PM
Ashton35
Jul 17, 2015 10:11 AM
