Need a little advice with cambers
Old Dec 6, 2006 | 05:39 PM
Nismo G's Avatar
I am going to start modding the suspension on my car, but im not going to install anything until i have everything (front and rear cambers, rear toes, coilovers, and the EDFC). I have been looking into the stillen products since i know their products are great quality and they are very reliable, but they also cost a little bit more than others. Is their another high performance company out their that produces reliable and good quality front cambers???
I heard a few weeks ago of a guy that i believe had his front kintetix camber arm break. Since i heard this i want to stay away from kinetix.
sean
Old Dec 6, 2006 | 05:49 PM
krazynuttz23's Avatar
i have the cusco front a-arms on mine right now ($385)! Works great and looks very durable! And I just bought a camber kit for the rear on ebay ($65). Works fine and did the job. hope this helps.
Old Dec 6, 2006 | 06:14 PM
cnaman's Avatar
goes with cusco... its about the same price man.. why the F would u buy a kinetix camber arm... just look at it man.. haha.
Old Dec 6, 2006 | 06:19 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
Cusco, SPC, and SPL all have very good quality alignment products.
-GP-
Old Dec 6, 2006 | 08:42 PM
Nismo G's Avatar
thanks guys! Does anyone on here have the stillen front camber arms??? If so please chime in let me know what you think!
Old Dec 6, 2006 | 08:48 PM
I'm going to be doing an alignment on a car with the full SPL camber/toe kit (Front and Rear) tomorrow, i'll let you know what i think as far as craftsmanship and adjustment levels.
-GP-
Nismo G's Avatar
-GP-
Awesome, thanks!
Old Dec 6, 2006 | 10:24 PM
N/A Project's Avatar
-2006 IP GT350-
I remember someone in here said front Cusco camber kit is not a good choice to go if you plan to drop the car a lot because of its limit camber adjustment. Some of them can't even get their camber back to factory spec because of that.
Anyways, I just order my SPC front and rear camber/toe/caster adjustments 15 minutes ago from Edward @ thmotorsports.com for a really good price compare on the market prices. And if you want to buy SPC camber kits, then PM "THMotorsports" and tell Edward that JJ told you about this and I think he should hook you up with their price real good.
Old Dec 6, 2006 | 11:36 PM
GreenGoblin's Avatar
The goblin resurrection
cool that is good to know
Old Dec 7, 2006 | 12:15 AM
mwarsh1's Avatar
Cambers Are Dangerous Keep It Oem Its Safer
Old Dec 7, 2006 | 12:28 AM
Mad Paradox's Avatar
J-Dizzle
Is this guy some kind of anti-camber kit activist?
Old Dec 7, 2006 | 12:38 AM
V35 Skyline GT's Avatar
6MT Coupe
Yup...oem is safe too This is what I think of oem.
https://g35driver.com/forums/g35-coupe-v35-2003-07/128360-scary-rear-suspension-system-broken-see-pic.html
Old Dec 7, 2006 | 02:21 AM
Pooner's Avatar
Is a camber kit necessary if you're only lowering the car an inch all around?
Old Dec 7, 2006 | 02:26 AM
6MT Coupe
Stock oem set-up has negative camber built in.
Dropping an inch will increase the negative camber more. More you drop, more negative camber will result.
Old Dec 8, 2006 | 12:34 AM
I just did an alignment on an 04 coupe lowered on 350Z h-techs, he had the SPL front camber kit installed and i adjusted it. The overall workmanship is great, very good welds and adjustment is very very easy. There was plenty of travel as well, i set it up at -.5/-.6 for optimal tread wear. My car is almost slammed on Tein Basics and i could have easily gotten my car back to -.5 front camber with this kit.
-GP-
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Picture Share
Feb 4, 2018 12:41 PM
Rose M
Oct 12, 2015 10:00 AM
6spdGspot
Oct 5, 2015 01:55 PM
dcsbh1
Oct 1, 2015 03:15 PM
