camber kit - stock suspension!
Dec 7, 2006 | 04:49 PM
Yes, our G's have some negative built in. It's for performance handling.
When you are in a turn with negative camber, the outside tires in the turn will have more of a footprint (zero camber) on the pavement, which results in better traction in the turn.
Quote: Isn't the negative camber on the rear by design? Does it serve a purpose?
I would think so... my 06 6mt definitely shows negative rear camber and I actually like it.. makes it look more sporty. But anyways, I think it's there a) on purpose and b) for a reason
Reply 0
Dec 7, 2006 | 06:33 PM
Quote: Yes, our G's have some negative built in. It's for performance handling.
hmm.. sounds fair. If thats the case, then ill just leave it. I can use the extra speed aroudn corners lol.
anywayz, if its not gona help me much on the wear of the tires then ill just leave it. now that i look at it, the back looks really sporty with the slight neg camber.
Reply 0
Dec 7, 2006 | 07:06 PM
Anyone know of hand I would assume that the coupe and the sedan spec for camber are different I just notice on my alignment sheet it says my car was the sedan bunch of duma$$es
Reply 0
Dec 7, 2006 | 09:06 PM
Sure, this is for an 2006 coupe with oem 19's.
Front:Toe-CamberDataFrontWheels.doc
Rear:Toe-CamberDataRearWheels.doc
Reply 0
