How do I disable TPS warning LED?
Old Dec 7, 2006 | 03:16 PM
brc888's Avatar
I swapped out my 19" summer wheels for my winter steelies - but now that TPS warning light is on all the time (makes sense since there's no sensors in my winter rims) - how can I disable this until summer time when I swap my tires back?
Anyone?
Old Dec 7, 2006 | 03:34 PM
FI'ed G's Avatar
I have an aftermarket wheels and didn't transfer my TPS sensor and I have no light. This should be off since there is no sensor installed and there nothing to monitor (in Theory )
My light only come up when driving over 80mph for over 1hr of straight driving. It usually turn off once I shutdown and restart the car.
Old Dec 7, 2006 | 09:38 PM
G35C4US's Avatar
The light in my '06 Coupe flashes when I start the car, but then stays on after a few seconds. It used to be annoying, but I've gotten used to it now. Would be nice to be able to shut it off permanently, though.
Old Dec 7, 2006 | 09:52 PM
ttrank's Avatar
Grocery getter
The only way to turn it off I know of is to not drive your car or put the other wheels back on.
Old Dec 7, 2006 | 10:15 PM
matt_0309's Avatar
The only way to disable the TPS warning is to put a cover sheet on your TPS reports. Did you get the memo?
Old Dec 8, 2006 | 12:15 AM
GeeWillikers's Avatar
Walking The Fine Line...
DOH! LOL..
Old Dec 8, 2006 | 12:32 AM
cungkpham's Avatar
i heard you can remove your instrument cluster with the 2 12mm (or 10mm) bolts on the bottom and remove the bulb... thats whats my tech said... BUT i think they are LEDs so, maybe he doesnt know what hes talking about... anyways...
i have the same "problem" for 6 months now. im just used to it.
Old Dec 8, 2006 | 02:10 AM
Calvin's Avatar
Overglorified Altima
just ignore it...
Old Dec 9, 2006 | 09:22 AM
Meth68's Avatar
I dont have sensors in my summer set (maya stm 20s) light was on for about 2min after they were put on, turned off havent seen it for 6 months
Old Dec 9, 2006 | 11:22 AM
ebuy929's Avatar
on my 04 coupe the light went off when the sensots wre out but its came on when driving for a while... then it wouldturn off
on my 06 coupe i changed my wheels and the light blinks every now and then, it stays solid permanently..nothing you can do the 06s just are a lil diff.
on the bright side the 06 coupes dont make that anoying beep alarm when the tps light comes on
Diode Dynamics
Accessories-Vendor
39
Nov 30, 2021 02:28 PM
g.spot
May 9, 2016 10:54 PM
G35xdriver04
Nov 7, 2015 08:31 PM
Gabe83714
Oct 6, 2015 06:40 AM
