steering vibration problme, help!!
Old Dec 8, 2006 | 12:31 AM
greek211's Avatar
i just did my 48k service, but i find that my car's steering(not very strong) virbration at the idel and low speed. i asked the dealer ,they said it is because of my flat tire. do you guys know what is the real problem. is it prossible the cold winter(-10 toronto)
Old Dec 8, 2006 | 12:57 AM
greek211's Avatar
no one knows
Old Dec 8, 2006 | 01:52 AM
greek211's Avatar
help
Old Dec 8, 2006 | 09:26 AM
chilibowl's Avatar
Set all your tires to 35PSI.
Old Dec 8, 2006 | 12:18 PM
KAHBOOM's Avatar
At idle?
Not sure what that could be if you are not moving.
If it's at low speed, that could depend on the type of tires you are running on. They may have become "out of round" while sitting still for en extended period of time.
another possibility is a bent rim.
Old Dec 8, 2006 | 12:27 PM
V35 Skyline GT's Avatar
6MT Coupe
At idle contradicts what you're trying to say.
I agree with kahboom on the tire thing. -10 is cold and tires could have flat spots from sitting. Does it get better after driving for awhile?
If it truly vibrates at idle (not moving) then you have something else going on other than tires.
Old Dec 8, 2006 | 12:28 PM
TheKnite's Avatar
Vibration at idle could be exhaust. Also check your rpms and see if they move, cause they should be steady.
Old Dec 12, 2006 | 12:06 AM
greek211's Avatar
it not always happen, when when you drive around and when your turn your steering's to one side then ,the vibration start. i did see some little move for
rpms, when i try to put the gear to the p. anyone can feel small vibration on teh steering ????
Old Dec 12, 2006 | 12:10 AM
slikmo22's Avatar
I could be wrong but it could be something wrong with your ignition also. Plugs and wires etc.
Old Dec 12, 2006 | 12:27 AM
greek211's Avatar
i let the dealer check it for me again today, they said it is normal. so i don't'
know what should i do , maybe going to anther dealer lol .
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
Kicknshift
Sep 3, 2015 09:35 AM
