Best Oil: Motul!!!
#46
Originally Posted by Jeff92se
That is incorrect. Mobil is just as "thick" as any other oil in it's viscosity class. (with a range that is). The reason why it pours better when cold is because synthetics feature a MUCH better cold flow capability. Not because it's thinner/thicker. You WANT this of an oil.
#49
on
Originally Posted by MaxGsII
I was a big-time believer in Mobil 1 (what-I-thought-was) 100% synthetic, but not anymore. Had my oil changed at my Performance Shop (JE Performance Imports, Baltimore) today, and the owner (James Evans) told me that Motul (for a whole host of reasons) was the best oil going! Needless to say, for me, it's Motul for the Coupe and FX from now on...
As a non-tech explanation, Motul is derived from Coconuts/Coconut oil and is less likely to build-up in the engine, etc. Plus James told me that I can expect to see 3-4 additional miles per gallon shortly!!!!!! And, it contains a detergent that keeps all valves clean!!!!
Any other Motul believers out there????
#50
on
Originally Posted by redriderr
Mobil 1 is def the best out of those you mentioned... I've used Shell, Mobile, Motul, repsol (bike), Amsoil. All those are good and I can barely tell the difference between them with the exception of the Amsoil...it feels smoother and lasts longer.
#51
on
Originally Posted by partyman66
This is not true about the Mobil 1 Oil to my knowledge. Mobil 1 Full Synthetic oil is actually a real true full Synthetic oil or at least it used to be as of a few months ago unless they've recently changed their formula. Amsoil, Redline and Motul are also true synthetics.
Castrol's American-Market "Full Synthetic" oil is actually not a true synthetic. They managed to get classified as a full synthetic becuase of some loophole in the standards of what is required for an oil to be classified as a Synthetic. The only true Full Synthetic Castrol oil out there is the German Castrol 0W30 oil which you can buy at Auto Zone for about $6 a quart.
Not anymore. I suggest read up on BITOG forums and do your research. It is no longer a true full synthetic like it use to be. They are cutting back on costs and went to a Group III base oil and not a PAO anymore. It just happened and has been tested on several virgin oil samples.
Amsoil, Redline, and Motul are the only ones that arre fully 100% synthetic.
#52
#53
Red Card Crew
Wow. I sorta just ignored anything Penzoil. Their Platinum synthetic has tested well over there? I'll have to see if they have it at Walmart.
Originally Posted by G35_TX
Not anymore. Actually Penzoil Platinum is better and cheaper than Mobil 1. Mobil 1 is a Group III oil now, not a full synthetic.
#55
Red Card Crew
Nice post. Very informative.
Originally Posted by ballisticus
Mobil 1 in the USA is now a group III base oil. Nothing wrong with that at all. In fact, it pretty much equals the "True" synthetic PAO's in performance except in very cold condition (-40 degrees) pour point. The main gripe people have is that Mobil is now using a less expensive Group III base stock, but charging the same for the product. Group III based oils can legally be called Synthetic as they are very highly processed and converted from crude sources.
The new Mobil 1 is still an excellent oil and will protect very well, but some don't like that Mobil didn't cut the price and pocketed the extra profits. Amazing. I thought companies were supposed to be as profitable as possible for their shareholders. This is America, not state run after all.
#58
Instead of blindly following recommendations of individuals who might not even be knowledgeable enough to pass along recommendations, why not send in a sample of your oil at your next oil change interval to Blackstone Laboratories or the like.
Some of you guys maintain such a short oil change interval that it would not matter what oil you used as long as the weight was correct. I would like to see how many individuals who are so meticulous regarding their oil change interval change their coolant and brake fluid with such regularity.
#59
#60
