Service Engine Soon light is on....
Old Dec 15, 2006 | 01:44 AM
Nismo G's Avatar
I searched around a little bit and found little information. My service engine soon light came on today and im wondering what it could be...? Obviously it can not be anything to serious or else i believe the check engine light would come on, right? My driver side tire is low, but im not sure if i have TPS. I have a 5AT 2003 coupe...not sure if it has TPS on it. I changed my oil yesterday everything was fine and then it came on today after i drove almost all day. I also heard it could be that the brakes need replaced, my brakes do need to be replaced, but idk if this is it?
Any input would be nice...
Old Dec 15, 2006 | 01:48 AM
abcquackyxyz's Avatar
check your gas cap? if not tighten it up, also bring it ot autozone have them check the code for free.
Old Dec 15, 2006 | 07:40 AM
Rayman's Avatar
Service Engine Soon Light
My Service Engine Soon light came on too. After reading some posts I went and checked my gas cap. That was it. Tightened the cap and the light went out in a day. Good luck.
Old Dec 15, 2006 | 09:28 AM
hootie981's Avatar
If tightening your gas cap doesn't work, take it into the dealer asap. The same thing happened to me last week and I took it to the dealer. Got a new TPS installed under warranty and all is well...
Old Dec 15, 2006 | 09:31 AM
g35rcr's Avatar
tps comes on the nav package equipped cars
Old Dec 15, 2006 | 11:38 AM
Nismo G's Avatar
Ok i do not have the navigation system, so i do not have the TPS. I filled the gas tank up yesterday, but the light came on yesterday way after i filled up the tank....wouldnt it have came on right when i drove off from the gas station if the cap wasnt tight.
Old Dec 15, 2006 | 11:44 AM
Calvin's Avatar
Overglorified Altima
does this only apply to 03 models?
cause i have an 06 base model (i dont have any options! :0) and i have tps.
Old Dec 15, 2006 | 12:01 PM
Mod Friendly's Avatar
TPS wont cause a check engine light to come on. A loose gas cap will cause it to come on. Not all 03s have tire pressure sensors either. All 06s do wether its base or not.
Old Dec 15, 2006 | 12:18 PM
logik05se's Avatar
yea my tps has been on for a while now ( over a month)...just recently my car started making some bad noise...which ive come to realize is the clutch rattle that our cars get from day one only ampliefied by 10...i really think this is the throwout bearing or the pressure plate...im bringing it in monday for service. Anyway yesterday on my ride home my check engine went on as well, im assuming it has to do with this problem but im not possitive.
Old Dec 15, 2006 | 12:23 PM
Nismo G's Avatar
i checked my gas cap it isnt that. I have 79,000 miles on the car..the light isnt comming on because of some 80K service i have to have is it?
Old Dec 15, 2006 | 12:24 PM
hootie981's Avatar
By "TPS" I mean Throttle Position Sensor---not Tire Pressure Sensor. Didn't you get that memo about your TPS Reports?
Old Dec 15, 2006 | 12:43 PM
Nismo G's Avatar
haha i was thinking tire presure...i did not here about the throttle body sensor....is that a common issue on the 2003 coupe?
Old Dec 15, 2006 | 10:45 PM
Go to autozone they have a machine to find out what code it is. It could be a lot of things..
Old Dec 15, 2006 | 11:09 PM
ARTofDESIGN's Avatar
Bump, but I prefer the dealer, however most here dont....
Old Dec 15, 2006 | 11:50 PM
Nismo G's Avatar
um never mind it went off....false alarm guys
