Can't feel the RE shifter
Old Dec 21, 2006 | 03:06 PM
White03G's Avatar
Unhappy Can't feel the RE shifter
Just got my RE shifter installed yesterday; I've been driving about 200 miles and still can't feel the RE differences. Anyone experienced the same? The 12mm bolt under the car is said to be tightened at 10 ft-lbs; how tight is it? I just tried to tightened as much as i can. Does it affects the shiftting process? I just can't think at any part of the installation that I did wrong. To be honest, I can't feel the RE yet; any suggestion?
Old Dec 21, 2006 | 03:38 PM
ughhness's Avatar
I just had it installed and the difference is noticible but it is not night and day difference... maybe it needs to be broken in or something.
Old Dec 21, 2006 | 03:43 PM
BayAreaRefuGz's Avatar
i fly low
i'm getting my RE shifter in today around 1ish. i'm glad i bumped into this thread...could anyone who have RE shifters come up and explain to us what the hell is going on??
Old Dec 21, 2006 | 03:45 PM
ughhness's Avatar
Well the throws are shorter and it is noticible.. lol
I just think that RE shifter is the best out of all the other shifters for the G.
Old Dec 21, 2006 | 03:55 PM
i fly low
do we REALLY have to jack the car up for us to reach the bolt underneath? is there a way we can get it from the top?
Old Dec 21, 2006 | 03:56 PM
Hi-TechG35's Avatar
+1 if you can't notice the difference in noticing shorter throws are you sure you ordered a RE shifter? DId you all order from an authorized dealer?
Old Dec 21, 2006 | 06:39 PM
GreenGoblin's Avatar
The goblin resurrection
ya Installed mine an hour ago it is night and day it is 10X easier if you jack the car up
Old Dec 21, 2006 | 06:44 PM
clifftrail's Avatar
Its only a 20% change in throws, thats not alot. The factory shifter is very good from the get go. Its not like putting a short throw in a mustang or camaro where the shifters are generally longer and sloppier.
Old Dec 21, 2006 | 11:55 PM
nm3th's Avatar
Are you using the stock shift ****?
I'm using an aftermarket **** and everything sits a lot lower. I can rest my wrist on the center console and flick it to shift.
Old Dec 22, 2006 | 12:03 AM
White03G's Avatar
Thumbs up
that's what i mean by "not really feel it"; I guess that's $179 for; still a bit smoother than stock. Isn't it a little longer than the stock? I thought it's about the same hight; just don't like the point it's higher than stock. I was expecting too much before getting the product because of so many positive feedbacks in here; that doesn't mean I don't like the new shifter. Good quality and improvement for $179. thumb up!
Old Dec 22, 2006 | 11:23 AM
Rphillips6487's Avatar
quick question guys, I have an 06 coupe with premium package and I happened to be going through a g35 catalog I had from prior months and it said that with the premuim package, the car already has a short shifter which I had seen before but never payed much attention to.
Now I just got my RE short shifter in several days ago. is it worth it or am I looking at pretty much the same as stock short shifter?
(no time to go research it as Ive been for a bit this morning and i need to head into work for a bit)
thanks guys,
-Russ
Old Dec 22, 2006 | 11:27 AM
mwarsh1's Avatar
About A Year Ago After I Did I Noticed It In The Ten Seonds Of Drving Also, Install It, Then Drive Around With It, Then After A Week Go To The Dealaer And Test Drive One With Out It Its Night And Day! Good Luck
dirtywally's Avatar
If I were to pick up an aftermarket short-throw shifter, my main priority would be reduction in shifter vibration. Have any of you who have this installed noticed a decent reduction in shifter vibration?
Old Dec 22, 2006 | 11:38 AM
yes my girl doesnt try and hop on it every second now. anyways yes it doesnt vibrate like it did before
Old Dec 22, 2006 | 11:57 AM
eemon10's Avatar
i really wanna get the RE shifter but i heard it voids the tranny warranty
