will touch up paint work?!
i got a scratch about the size of a quarter ~ will applying OEM touch up paint be more noticable than jus leaving the scratch there?! any suggestions?!
thanks!
thanks!
the paint got scratched all the way to the metal part~ i dont think touch up paint is going to work huh...... whats the best way to fix it?! repainting the whole rear fender? boohoo.... :'(
i used touch up on my ip coupe....the touch up from infiniti is a 2 stage paint...first you put the flat, then the pearl. From alot of times of trial an error i came to the conclusion that its must less noticeable if you dont use the pearl...just use the flat and it will look best. For some reason the pearl made it almost a completly different color.
And i did it the rite way, with buffers and compounds etc. But try it out lemme know which way works best for you.
