7440 LED lights for Turn Signals.....
Old Nov 14, 2003 | 12:32 AM
ozracer01's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...category=33713
I was thinking if this would look nice? Has anybody tried replacing the stock rear turn signal bulbs with LED bulbs? Secondly, whats a good automotive LED bulb manufacturer, that makes odd sizes such as 7440, or 1156, etc.
04 DG Coupe, Prem Package, Aero
Old Nov 14, 2003 | 07:59 AM
Renegar's Avatar
Re: 7440 LED lights for Turn Signals.....
If you don't mind having a "hyper blinker" then it would be fine.
By that, I mean it will blink way faster than usual.
Laser Red 6MT Coupe / Delivered by Grubbs Infiniti
Old Nov 14, 2003 | 08:16 AM
raysg35's Avatar
Yes I have, and you will need a 6ohm 50watt resistor to make it work right or you will have a very fast blinker. I would also recommend getting a 7443 with at least 11 LED's, because I find that 9 LED's just are not bright enough in the day time, but I'm in sunny Florida.
Old Nov 14, 2003 | 11:14 AM
afr0puff's Avatar
Supa Dupa Moderator
There are no LED cluster bulbs that currently emit more light than the OEM bulb, if that is what you are thinking, unless instant on/off is your reasoning.
http://www.anythingbox.net
Old Nov 29, 2003 | 11:50 AM
gwise's Avatar
Presuming the resister is installed, will the 11 led version fit into the existing rear turn signal opening? How about the front bulbs while we are at it?
I think the instant on-off would complete the picture.
PS: Do you put the resister mentioned at the relay or inline with each bulb?
Old Nov 29, 2003 | 11:02 PM
raysg35's Avatar
the resistor goes on the binker wire to the ground wire right at the bulb socket.
<P ID="edit"><FONT class="small"><EM>Edited by raysg35 on 11/29/03 08:23 PM.</EM></FONT></P>
Old Nov 30, 2003 | 06:09 AM
gwise's Avatar
Thanks for the reply
Mry
Mar 3, 2023 01:03 AM
Luisgalvan33
Jul 19, 2018 08:16 PM
mtlruss
Dec 20, 2015 01:51 PM
MT6002
Lighting
Jul 21, 2015 01:13 PM
