ECU
Old Nov 14, 2003 | 10:39 AM
silver350's Avatar
ECU
Once you resetted the ecu, would the stock bose system be resetted as well...then do you have to input the code for the bose again?? if so, do i go to the dealer???
Old Nov 14, 2003 | 03:55 PM
OOOOA3's Avatar
Alumni****
Re: ECU
It depends on which method you're using. If you're doing the quick reset, then no. If you're doing the battery disconnect, then you might lose your presets. That's bout it.
Old Nov 14, 2003 | 03:58 PM
gsg's Avatar
gsg
Re: ECU
What about the Homelink memory????
Old Nov 14, 2003 | 04:21 PM
phdvamp's Avatar
Re: ECU
I've done the 12 hour disconnect. I lost my radio presets and my seat positions, but I did not lose my homelink setting (my garage door still opened).
03.5 5AT Sedan
<font color=black> Black on Graphite / Prem / Sport / Aero / Winter / Tint </font color=black>
Old Nov 14, 2003 | 04:36 PM
Msedanman's Avatar
O.F. Administrator
Re: ECU
Once you reset the ECU by disconnecting the battery, you lose the radio presets, odometer mileage setting, and Navi average mpg's. If you've got a Sedan, you also lose the seat memory settings. The Homelink isn't affected on either ride.
The Easy reset is the way to go. It's quick and you lose no settings, but you must practice the timing for that method.
You'll find info on that reset in our DIY forum under 'ECU Resets'.[img]/w3timages/icons/smile.gif[/img]
G/L
GSM
<font color=red>GSM</font color=red> <font color=black>Silverstone Coupe</font color=black>
Old Nov 14, 2003 | 06:20 PM
weaksauce's Avatar
Re: ECU
hope you mean the tripometer settings...otherwise all used g35s would have 2 miles on them! ^-^
Old Nov 14, 2003 | 11:29 PM
Bigsmasher's Avatar
Re: ECU
do we drive aggressive in tip tronic or auto mode for the car to adapt?
2003.5 Black w/ Willow G35 5AT
Premium / Sport / 5% Tint / Injen intake / 20" rims
Old Nov 14, 2003 | 11:31 PM
DragonGcoupe's Avatar
Re: ECU
Bigmasher .. I believe its either .. But I don't have an AT so I dont' kno ..
I was say .. You can reset ur odometer =)..?
Black / Black 2004 GcoupeMT. Premium. Splash Guardz.
Old Nov 15, 2003 | 03:10 PM
silver350's Avatar
Re: ECU
losing the bose presets, does that mean it wont play music at all? or the radio presets?
Old Nov 16, 2003 | 08:10 PM
skm7's Avatar
Re: ECU
Do you need to do all procedures including Accelerator Pedal Release Position Learning , Throttle Valve Closed Position Learning , Idle Air Volume Learning (Throttle Position Learning) , or just the first part?? Sorry I don't know much about this stuff..
Thanks for your help!!
Old Nov 16, 2003 | 08:17 PM
Serum's Avatar
Re: ECU
you shouldn't be allowed to drive the car...excuse me.
then again, i confused LSD w/a rear wheel drive. i guess i shouldn't be driving this car either. >=P
Old Nov 16, 2003 | 08:24 PM
Msedanman's Avatar
O.F. Administrator
Re: ECU
<hr></blockquote>
Yah, It's prolly good it's not that easy. LOL
For sure I meant the trip-o-meter. [img]/w3timages/icons/tongue.gif[/img]
Old Nov 16, 2003 | 08:27 PM
Msedanman's Avatar
O.F. Administrator
Re: ECU
Silver350, by disconnecting the battery, you lose the radio presets only. The radio works fine otherwise. You just have to reset your presets.
GSM
Old Nov 16, 2003 | 08:32 PM
Msedanman's Avatar
O.F. Administrator
Re: ECU
SkM7,
<hr></blockquote>
You should be able to just do the first part (the ECU reset). If there's no way to get that reset to work, then it's probable that you'll have to do one or more of the other procedures.
I've not heard of anyone who has had to do that yet tho.
That ECU reset takes a little practice.....so be patient and persistent.
GSM
Old Nov 17, 2003 | 01:35 AM
skm7's Avatar
Re: ECU
Thanks gsedanman!! [img]/w3timages/icons/smile.gif[/img]
