Replacement Fuel Tank!!!
Old Jan 4, 2007 | 12:15 AM
STL_G's Avatar
I took my car into the dealer because sometimes when I fuel the G, the gas pump shuts off. I know alot of others have had this problem. They replaced the shutter valve 6 months ago or so. The dealer said that since they already replaced the valve, the only option is to replace the fuel tank. That is $1100 to replace, since I am out of warranty. Who the hell has heard of having a gas tank replaced????
Old Jan 4, 2007 | 12:31 AM
jinubob81's Avatar
Evil Bastard
you're already out of warranty? you must have a lot of miles on it.
regardless, they should still take care of it, since you had that same problem back when you were under warranty, and they weren't able to fix it properly.
you could try to push for it to be considered an emissions issue, which has a longer warranty coverage. you'd probably have to get help from your attorney general's office, if they'll help you at all.
good luck.
Old Jan 4, 2007 | 12:40 AM
STL_G's Avatar
67,xxx miles strong!
Old Jan 4, 2007 | 12:49 AM
MentalSpine's Avatar
lemon law
Old Jan 4, 2007 | 10:22 AM
partyman66's Avatar
Fuel Tank?
It's not the fuel tank. If the pump at the gas station is shutting off while you fill the tank, then you know that the fuel tank is serving its purpose at the very least... which is to hold fuel in a pressurized fashion. The fuel tank does nothing more than that... it's just a cell for holding the fuel. The problem is probably your fuel filler hose again.... but definitely not the tank.
Only reason you'd have to replace a fuel tank is if it rotted out, was severely dented/cut/damaged from running over stuff which hit it as it passed under the car, or the mouting points for your fuel pump assembly were broken off or otherwise destroyed.
Old Jan 4, 2007 | 10:29 AM
XCELR8's Avatar
funny how they recommend replacing the expensive stuff AFTER your out of warranty
Old Jan 4, 2007 | 10:37 AM
g35rcr's Avatar
i had mine replaced under warranty for the same thing...had a bad baffle
Old Jan 4, 2007 | 11:00 AM
bassholic's Avatar
Damn i have an 03 and don't break warranty till 1/08. Do you HAVE to get the fuel tank replaced?
Old Jan 4, 2007 | 11:26 AM
Pivo's Avatar
why wont you just get gas at stations that work like shell and mobil and not worry about this crap. My car will never fill up at certain station that have old pumps, but from my experiments shell and mobil always works
Old Jan 4, 2007 | 11:40 AM
LjN_728's Avatar
Dude that sucks so many *****! Does it happen all the time or like 5/10 times?
Old Jan 4, 2007 | 12:18 PM
g35rcr's Avatar
there was a tsb for the fuel tanks being defective when i had mine done because, i had them replace mine THREE times...
Old Jan 4, 2007 | 01:35 PM
pinoiballer01's Avatar
i just brought my car to the dealership last week for the same problem. i have an 06 and the dealer said they have to replace the filler neck and i think a valve inside the tank because of somekind of pressure or something that makes the pumps go off.
Old Jan 4, 2007 | 07:01 PM
kev301's Avatar
just got mine done for the same prob...
Old Jan 4, 2007 | 07:04 PM
jjyellow's Avatar
Had to get my tank replaced after they serviced the valve, b/c after that my gas gauge wouldn't work properly
Old Jan 4, 2007 | 07:22 PM
STL_G's Avatar
The last time this happened to me, I was fueling at Mobile. I from the picked my car up this morning from the dealer. They said that Missouri has a law that the gas pumps must recover the vapor released while fuelling. This apparently effects our cars on occasion. I talked to my mother today and she has this problem w/ her BMW. The dealer also said that changing the tank may not solve this problem. I think since this happens occasionally, I will not worry about it.
