help g35 coupe problem!!!
Old Jan 6, 2007 | 07:26 PM
taikien's Avatar
im having problem with my slip+ brake+vdc off lights being on.change all 4brake pads to ceramic+4 drill-slotted rotors.also top off my brake fluid reservior but didnt help.car accelerate fine.its 2003 model out of warranty and 73000 miles on it.and also passenger window would roll back down when use in auto.and windshield tank leaking empty in one day.
Old Jan 6, 2007 | 08:04 PM
jinubob81's Avatar
Evil Bastard
did you forget to plug some wires back in or something?
Sounds like you need to get yourself a OBD diagnostic scanner, or get it scanned by the dealer or even autozone. Dealer should be able to tell you a specific problem (which you could then fix by yourself), or autozone can tell you a general reason for the problem.
As for your power windows acting up, I think there is a TSB (tech. service bulletin), so you could follow that for a fix, and for the windshield washer tank... well, it has a leak. Go get a new one.
Good luck!
Old Jan 6, 2007 | 08:10 PM
Calvin's Avatar
Overglorified Altima
Old Jan 6, 2007 | 08:12 PM
bull3t's Avatar
for the window all you have to do is reset it...very easy...there is a thread on it in the g35 sedan section...
Old Jan 6, 2007 | 11:25 PM
jdmeg21's Avatar
get the odb scanner from autozone. they'll let you use it for free. It seems like something got unplugged while the battery was still plugged in. Maybe you just need to reset the ecu or plug something in that might be loose
Old Jan 7, 2007 | 12:05 AM
cutiewolf's Avatar
gas tank meter problem and fuel hose recall...... got that fixed under warrenty.....
edit:im also got 03 coupe.
ps. unscrew - and + battery line leave it over night..it will reset everything. it might help!
Old Jan 7, 2007 | 12:52 AM
Furious Vegas's Avatar
I just had the same thing happen and did the research. I don't think you can just cap off the brake fluid. It has to be drained and changed. That was all I needed, no pads, no rotors.
chinee
Jun 10, 2024 07:48 PM
mike730
Jan 12, 2018 04:25 PM
ClwMike
Jul 23, 2015 12:55 PM
attarday
Jul 15, 2015 04:03 PM
