Lower my car
Jan 8, 2007 | 10:43 PM
I have 18's, i want my car to sit real nice on 'em. I would like it to be as low as possible but still be practical, should i get a camber set or just get tien s-techs? Money isnt that big of an issue(within reason) so which set will give me best performance with highest aesthetic appeal? Thanks
-noth1ng
Reply 0
Jan 8, 2007 | 10:47 PM
tanabe df210's but youll definitely want a camber kit
judging from your question, you sound a lil confused. youll need a camber kit to fix the negative camber after lowering your car.
or maybe i just misunderstood your question. if that's the case, then my bad.
Reply 0
Jan 8, 2007 | 10:56 PM
i have stechs on my car and I didnt not get a camber kit the alignment shop got it back into spec but it could be better a camber kit would be recomended
Reply 0
Jan 8, 2007 | 10:59 PM
really? i barely got back into spec with my z h techs iirc.
how far outta spec are you in the front?
Reply 0
Jan 8, 2007 | 11:22 PM
yeah....definitely confused, thought camber kit was just a better (and more expensive) way to modify the suspension. Any one have suggestions on the best combination that keeps a relatively smooth ride (im no grandma) and improved performance?
Reply 0
Jan 8, 2007 | 11:25 PM
well since you say money isnt an issue (within reason )
tein basics would be a good choice
or if you're looking to get springs only...i'd go with the s techs or df210's...however, i'd also get some spacers...
just my two cents
Reply 0
Jan 8, 2007 | 11:29 PM
Quote: yeah....definitely confused, thought camber kit was just a better (and more expensive) way to modify the suspension. Any one have suggestions on the best combination that keeps a relatively smooth ride (im no grandma) and improved performance?
You may be thinking of coilovers, not camber. That is the best way to lower your car and improve your performance. Tein CS coilovers maintain a smooth ride while also slightly improving performance.
Reply 0
Jan 8, 2007 | 11:30 PM
theyre also expensive
Reply 0
Jan 8, 2007 | 11:47 PM
exactly, coilovers! wow they are proud of those tein CS's coilovers, 1k plus...any other suggestions that won't kill my whole budget (2400)?
Reply 0
Jan 8, 2007 | 11:53 PM
tein basics
tein flex sounds like itll be too rough for what youre looking for
Reply 0
Jan 9, 2007 | 12:09 AM
i just found the tein basics, reasonable price...will that lower my car an inch or more? Thats the main purpose.
Reply 0
Jan 9, 2007 | 12:14 AM
yep
i think you can go as low as -1.6" in the front and -1.4" in the rear
Reply 0
Jan 9, 2007 | 11:09 AM
aero when I get home I will look at the alignment sheet
Reply 0
Jan 9, 2007 | 03:20 PM
noth1ng how much are you getting the Tein Basics for..and from where??
Reply 0
Jan 9, 2007 | 03:59 PM
i just spent my saturday installing my stechs. im pretty happy with the results. should probably get everything realligned though lol. cant be good driving out of allignment
Reply 0
