Rim Question Help!
Rim Question Help!
Alright I have an 04 G35 Coupe and i have just purchased rims with tires from the forum. I know that on my G the stock 18's are 18x8 with staggered tire sizes and i just purchased 19x8.5 with 235/35/19 all around. Is this going to be an issue at all on the G? If so what do i need to do to correct it besides just putting staggered tire size on the rears? If i do just put the staggered size tire on my car will this be fine? Please let me know!
Also the rims are a +38 offset....I have bought 25mm spacers for the rears and considering 20mm for the front...will this look ok? or will they still be tucked under there taking away the aggressive look?
If you have the 18" performance wheel/tire option, your OE tire size in front is 225/45/18, giving you an overall tire diameter of ~ 25.9". Your rear OE tire size is 245/45/18, giving an overall tire diameter of ~26.8". However, those tires are only 25.5" overall diameter. It shouldn't change much in the fronts, but I'd highly recommend getting some larger tires for the rear, at least a 245/40/18 (which would put you right back at 26.8").
-Jerome
-Jerome
Originally Posted by aHero4Eternity
i cant remember for sure but i think itll fvck with your vdc or something
FS[Canada]: 16" Ronal Rims with 205 65R16 Michelin X-Ice
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
