Using Tire Chains w/ 19" Wheels?
I live in Seattle and don't feel it's necessary to purchase winter tires just for the 0-2 minor snow storms per year. However, there will likely be situations where I'll be forced to drive in snowy conditions for a short period of time.
Does anyone have any experience using tire chains with the stock 19" rims (w/ summer tires)? I'm wondering if it's possible without damaging the car/rims, and if it provides adequate traction/control? If so, a specific brand/type recommendation would be awesome.
Thanks
Thanks
nothing good can come of putting chains on your wheels.
my advice. go get yourself a cordless impact wrench and one of those floor jacks that only needs two pumps to go to full height.
Then get a set of rims, whatever condition it doesn't matter, even size doesn't matter, throw a set of snow tires on them, and use them when when you need to.
With the jack and the impact wrench changing out all 4 ties shouldn't take you more than 15 minutes.
Sure this may cost more. But think about what could happen if you throw a chain or go sliding into a curb in the snow.
He's probably referring to CABLES, not chains. But they would be a pain to put on. Plus since the main roads are generally clear, you would be hampered by the slow top speeds. ie.. 40mph or something.
You have a performance RWD car with performance summer tires. Deathwish 2000 in the snow. The trade off for that performance and handling is you need to get some (at the very least) all seasons or better yet, a set of dedicated snow tires. I highly suggest getting some oem 17s or 18s and put some SNOW tires on them. Then just drive on those for a few weeks out of the year.
Is there snow tires that actually have little spikes built into them. i live in florida so we never worry about things like this, but in the james bond films and a few other films when the cars were on ice they had these little metal stubs that came out of the tire...Im sure this is fake and just made up, but you never know these days. Has anyone seen these before?
-sean
-sean
Well I just called Les Schwab and the guy said that chains would likely damage the rims and he wouldn't recommend it.
This sucks because where I live I really don't think it's worth the $$$ for winter rims/tires when it only snows once or twice at the most. At the same time it really sucks being completely immobilized on those days.
Ugh.
Ugh.
Um.... you have got to be effin' kidding me right? haha!
You mean studs, stud.
![EEK!](https://g35driver.com/forums/images/smilies/eek.gif)
-sean
-sean
-sean
-sean
yes those are called studded tires, and they are indeed basically metal stubs. I went to school in Montana and had studded tires in the winter when I was there...
they work well but they really tear up the roads.
I live in seattle as well, and I think its totally worth it to have winter wheels/tires, not just for snow, but to limit wear and tear on my summer wheels from the winter weather. Also, I would think you would need 2 sets of chains for the front and the rear because if you mount on the front, you won't get traction to start, and if you only put on the rear, you won't be able to steer or brake effectively. Just invest in some winter wheels and tires, if you use them sparingly, they should last at least 3 seasons
1. short projecting part.
2. a short remaining piece, as of a pencil, candle, or cigar
So i could be talking about a stub of metal comming out of the tire, but yes a stud. Thats what i thought i typed...and i guess i didnt haha!!
![Big Grin](https://g35driver.com/forums/images/smilies/biggrin.gif)
-sean
0_0 DO NOT put cables on your 19's. I'm pretty sure it will mess up the low profile tires. Also, the tires that Infiniti uses with these 19's are summer performance tires. This basically means that they have a tolerance for high temperatures but when it's cold out, the rubber becomes harder and you lose LOTS of traction. Just get the dedicated snow tires + rims for those parts of the year when snow would be a problem. It's a lot safer to spend $$$ on dedicated snow tires & rims than on repairing damage to your G after a bad accident from no traction.
Also, I'm pretty sure they do not have tires with studs anymore because they totally ruin the roads. :P
Buttt.... do what you want. This is jmo. :P
