voltage question?
Old Jan 19, 2007 | 09:09 PM
PEARL-G's Avatar
voltage question?
i just finished installing my system and when it hits, my car flutters. i watched my rpm's bounce with the beat on the highway. i do have a alumapro 15 farad cap. so any of you guys out there with big systems like mine, please give me some advice.. thanks
Old Jan 19, 2007 | 09:16 PM
srmfball's Avatar
Id like to know this too. The same thing happens to me. I have a 5 farad cap.
Old Jan 19, 2007 | 10:13 PM
PEARL-G's Avatar
did you do anything? man cause it seems pretty bad.
Old Jan 19, 2007 | 10:18 PM
Glycerine's Avatar
15 farad???? Holy.. Chances are, your cap is never charging fully. You're still pulling from the battery. I don't know what the amperage of the G's alternator is, or if you're running stock battery (i'm guessing so), but i'm imagining you're pulling too much for the battery and it's punching the alternator in the *****. Revs to try and boost the alternator (belt).
i'd check what you're pulling, and remember to add the car's electronics in, and see if you're exceeding the limits of your charging system. If you are, hell, it might be worth it to borrow a deep cycle battery like the optima yellow top and see what that does for you. If nothing there, you need to boost the alternator by replacing with a high output one. You'll most likely loose a few ponies turning it tho.
If you're cool with your gear + car electronics, and flying under the limit, then i don't know. Look for a short or something that connects when your sub hits.
Again, i'm just guessing here...
Old Jan 19, 2007 | 11:47 PM
PEARL-G's Avatar
anyone else have any other ideas?
Old Jan 20, 2007 | 01:03 AM
its a g35's Avatar
far as i know the 06g c is amping out 115a,from stock,alt. how many watts are you pushingbye the way, what amp? sounds like your a hard hitta, i had my kx1200.1 with two 12 l7 on my scion tc i had and it was barly burping 80amps, from the alt, running no cap, and i was fine at half the volume dropping pictures off my wall, with nothing else pulling except the ac and stereo
Old Jan 20, 2007 | 01:10 AM
hai109's Avatar
Tell us your complete set-up...Wire thickness, amp, speaker, HU...Could be your Alternator...
Glycerine has a point...You only need to get a certain Farad Cap for certain applications...15 Farad cap is for a huge number of amps and speakers...Usually those in competition...That cap is over kill for your system..I'm assuming you have just the basics...
srmfball's Avatar
I have an Alpine 1.1000 amp running 2 10W6v2's with 2awg wire. It really pisses me off I thought the cap would fix it but it only helped a little bit.
Old Jan 20, 2007 | 01:12 AM
hai109's Avatar
Did you guys use a resistor to first charge the cap? They said when you first install the cap. You need to get a little resistor to slowly charge the cap.
Old Jan 20, 2007 | 01:21 AM
srmfball's Avatar
Yea, I did. The cap helps but it does not seem like a complete solution.
Old Jan 20, 2007 | 07:41 PM
PEARL-G's Avatar
ok,
for the subs, that all that really matters here cause that the only amp drawing that kinda voltage, is a audison vrx-1502. its a class AB amplifier, from the battery i have kicker 1/0 gauge wire to a 15 farad alumapro cap. i think the only fix here would be a H.O. alternator. but i heard that hurts performance. i am just hoping that there is a quicker/cheaper fix.
Old Jan 20, 2007 | 07:43 PM
PEARL-G's Avatar
the alpine amplifier is a class D amp, imagine mine being class A/B.
Old Jan 20, 2007 | 08:48 PM
ltrrtl218's Avatar
from what i read over at caraudio.com forum caps are bascially useless and just another way to waste some money and dont really help stopping the lights flicker in ur car.
Old Jan 20, 2007 | 10:37 PM
PEARL-G's Avatar
caps will NOT stop lights from flickering! caps help your vehicles battery. if anyone wants further CORRECT info regarding caps go to www.the12volt.com. places like circuit city and best buy give out false information in order to sell something. besides g35's have HID's which wont flicker.overall, yes they are pretty much a waste of money, especially the pringles can lookin ones. take the money you want toi vest into a cap and buy a high output alternator. i mean a 15 farad alumapro cap is $549. thats basically the price of an alternator. the only reason why i have one is becuse i got mine basically for free. so.
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
migurus
Sep 5, 2015 09:39 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
UT G35
Sep 3, 2015 03:58 PM
erich2780
Sep 3, 2015 03:23 PM
