p0132 oxygen sensor
Old Jan 21, 2007 | 05:18 PM
pmav's Avatar
p0132 oxygen sensor
Question, does anyone know what P0132 Front O2 Sensor, Bank 1 Rich Shift Monitoring error code be caused by. I changed the oxygen sensors but still get this issue.
Local infiniti specialist says that ecu needs to be replaced.
Quick history. Bought a rebuild car(not the smartest thing) and now have this issue. The car is an 05 AT. The ecu I found out is from an 03. Would that cause any issues?
What about 87 octane gas would that affect it also?
Thank you in advance
Old Jan 21, 2007 | 05:19 PM
Calvin's Avatar
Overglorified Altima
do you have an 05 6mt? if so, you have a revup engine whereas the ecu from the 03 you have is for a nonrevup (whether or not the 03 is 5at or 6mt). i'm assuming that would be the problem (but idk...hah)
Old Jan 22, 2007 | 08:51 AM
pmav's Avatar
the car is actually automatic. Does that change the situation?
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
KallDay86
Jan 8, 2016 12:42 AM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
vamarris
Sep 26, 2015 12:56 PM
