So my car just lost all power...
Old Jan 22, 2007 | 05:38 PM
Mr. Uy's Avatar
Yesterday when I was pulling into my apartment and waiting on the gate to open, all power inside the car slowly faded out. It was raining and below freezing, so I had quite a few things running, including windshield wipers, satellite radio, ac on heat, seat heaters, and headlights. I turned the car off at the key, put it in park and it also started right back up without any problems. I was wondering if anyone ever had this happen to them? My only guess is I somehow overloaded the system...
Old Jan 22, 2007 | 05:39 PM
doomsday123's Avatar
Maybe the alternator going out?
Old Jan 22, 2007 | 05:50 PM
Mr. Uy's Avatar
the battery was fine the last i checked (less than a month ago) but I will probably have to wait till i get home to check, i almost assumed i put too great of a load on the alternator/battery, and being that when you slow to a stop the accessory belt slows that it might be related
Old Jan 22, 2007 | 06:28 PM
madscientist's Avatar
ever see close encounters of the third kind?
lol
i had to.
Old Jan 22, 2007 | 06:57 PM
jdmeg21's Avatar
bad altenator or the connection to the altenator. Same thing happened to my hatchback. everything went dim. I turned off the headlights and a little bit of power came back on the center console, hit the turn signal or headlight and radio and everything would shut off. I checked the altenator and the cable that was connected to the ground bolt was loose and not making good connection.
Old Jan 23, 2007 | 01:53 PM
Mr. Uy's Avatar
thanks, i will have to go home and check all the connections when i get home
Old Jan 23, 2007 | 01:57 PM
Hi-TechG35's Avatar
Sounds like the alternator is going. You may also wanna check your battery connections.
Old Jan 23, 2007 | 02:13 PM
Rphillips6487's Avatar
alternator
Old Jan 23, 2007 | 02:21 PM
AboostedG's Avatar
Are there any aftermarket Alternators?
Which Battery would you recommend for a huge sound system, plus other things...
Old Jan 23, 2007 | 02:57 PM
TwiBlue's Avatar
Cai?
Old Jan 23, 2007 | 03:37 PM
mephistomyhero's Avatar
For all those who had a bad alternator, if it goes bad within the warranty, will they stealership replace it?
Old Jan 23, 2007 | 03:42 PM
g35rcr's Avatar
remember the stock battery is a serviceable battery, you need to add distilled water to it
Old Jan 23, 2007 | 04:46 PM
g35ctuner's Avatar
there's a loose nut behind the wheel.
Old Jan 23, 2007 | 09:06 PM
Man, you are mean! Calling Mr. Uy a nut!
