too lean
Old Jan 22, 2007 | 06:05 PM
techi13's Avatar
too lean
how bad is it for your engine if your engine is running too lean (lean enough that the "service engine soon" light is on)?
does it require immediate attention? or will it affect the longevity of the engine
thanks in advance for any response
Old Jan 22, 2007 | 06:08 PM
Jerze Rat's Avatar
*Gunner Mother F*cker*
Well it depends how lean you are running. IMHO i would get it checked out as soon as you can. I blew the motor on my supra because it was running to lean. The tuner tuned it way to lean to squeeze out more HP. Better safe than sorry. Learned that one the hard way.
Old Jan 22, 2007 | 06:10 PM
Jeff92se's Avatar
Red Card Crew
My question is how do you know your engine is running "lean"? If it's running THAT lean that is causes a CEL (most likely for a cylinder misfire/injector misfire), then yes, that's dangerous.
Old Jan 22, 2007 | 06:26 PM
ttrank's Avatar
Grocery getter
Kaaaa-bbbboooooommmmmm!!
Yes, have it looked into ASAP.
Old Jan 22, 2007 | 06:40 PM
Jerze Rat's Avatar
[QUOTE=ttrank]Kaaaa-bbbboooooommmmmm!! QUOTE]
Yep thats what i heard followed by a bunch of... F%#&, SH&#, MOT&^F%^KER... LMAO
Old Jan 22, 2007 | 07:28 PM
txgcoupe's Avatar
So what makes you think your engine is running lean?
John
Old Jan 22, 2007 | 07:30 PM
SeOuLG35's Avatar
what do you mean by LEAN???
Old Jan 22, 2007 | 07:32 PM
techi13's Avatar
i checked at autozone (computer scanner) and the code it threw, turns out to be because it running too lean...
i only have a couple of bolts ons, no FI
what are my options to fix this problem? i'm sure a reflash by technosquare would do the trick...what are some other options?
once again thanks for the imputs
Old Jan 22, 2007 | 07:33 PM
techi13's Avatar
lean, meaning the air/fuel mixture has too much air compared to the fuel
Old Feb 9, 2007 | 04:55 PM
ma_sha1's Avatar
Get rid of the MD spacer if you have one.
Old Feb 9, 2007 | 05:30 PM
BadBoy06's Avatar
x2!........
Old Feb 9, 2007 | 06:26 PM
Skaterbasist's Avatar
Retired SuperMod
UTEC
Old Feb 10, 2007 | 12:43 AM
techi13's Avatar
my last mod was put in about 4k before the ses light went on...
another problem...i think my car is consuming too much oil...so i'm considering going back to stock before taking my car into the dealership
what a pain in the a$$
whats a good price for the UTEC? and how much should i be looking at to get it installed?
