Water leaking onto pedals...WTF
Old Jan 24, 2007 | 10:50 PM
MastaRip's Avatar
so im driving in southern florida, where it rains basically once a week at least. It starts raininig like a b1itch and i was wearing sandals, like the only time ive ever worn then while driving. So as its raining hard outside i feel water drippin on my feet...im like wtf??? the clutch is getn all slippery and $hit.......it happened once when i was in a car wash machine...but i thought it was the car wash....the only mod ive had done to my car that i think couldve fuked with it is a viper alarm installed....any1 kno what the problem is? this is urgent...
Old Jan 24, 2007 | 11:04 PM
Casetay's Avatar
1ClssyG
yeah I have the same thing happen in mine but mine only happens when its real hot out and I have my A/C on. I think mine is just A/C fluid or something. its weird though for sure
Old Jan 24, 2007 | 11:19 PM
slikmo22's Avatar
In order to install something like a viper alarm you have to run a couple wires (tach, hood pin, siren) to the main brain which is usually mounted under the steering column. So maybe when they ran those wires into the car they didn't properly seal the hole they made.... where'd u get it installed?
Old Jan 25, 2007 | 12:23 PM
MastaRip's Avatar
i got it installed in senor stereo, i need to figure out what happened quick...
Old Jan 25, 2007 | 12:26 PM
Jtrain's Avatar
Happens to me sometimes to, sure would like to know what it is.
Old Jan 25, 2007 | 01:02 PM
DVFlyer's Avatar
I had bubbles come out the floor vents while in a car wash (not a G35). I guessed it was because I had the vent set to fresh air v.s. recirculate.
Old Jan 25, 2007 | 01:05 PM
ttrank's Avatar
Grocery getter
I had the same problem over on the other side. When we took out my engine the main harness would not seal back up as well. Had to add some silicone to seal it back up.
Old Jan 25, 2007 | 01:09 PM
watsgoodG's Avatar
they have to drill thru the firewall to get inside the car thats where its coming from
Old Jan 25, 2007 | 01:42 PM
g35rcr's Avatar
make sure to check all seals, also the weather stripping on top of the firewall needs to be checked
MastaRip's Avatar
firewall?...any pics....
Old Jan 25, 2007 | 05:17 PM
MastaRip's Avatar
bump...whats a firewall
Old Jan 25, 2007 | 05:47 PM
GR8TG35's Avatar
The firewall is the back metal area of your engine compartment....behind the motor......................it has weatherstrip that runs along the top to seal the hood to the engine compartment area....check to make sure the weatherstrip has not come loose anywhere.....
I still don't think that would be the problem area....maybe the drains by the winshield are clogged, and its not letting the water run off from the windshield properly........that would be my first guess....also, look around the wiper assembly/arms.......is there any place water could easily enter through to the interior........
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
KallDay86
Jan 8, 2016 12:42 AM
hrdwirk1
Oct 2, 2015 06:34 PM
NyCrAzY
Oct 1, 2015 09:19 AM
vamarris
Sep 26, 2015 12:56 PM
