wheel spacer!
Old Jan 30, 2007 | 08:26 PM
ELE's Avatar
ELE
wheel spacer!
Anyone know where i can find a 35mm spacer for coupe?.....i need a pair of 20mm and 35mm...!!` plz help~
btw i found a good place in vancouver for powder coating....and cost only about $30ca per a rim, give me a message if u r looking for one!!~
Old Jan 30, 2007 | 09:30 PM
papiloco21's Avatar
www.ichibausa.com
www.optionimports.com
Old Jan 30, 2007 | 10:02 PM
ttrank's Avatar
Grocery getter
35mm! Going widebody?
Old Jan 31, 2007 | 05:25 PM
ELE's Avatar
ELE
Originally Posted by papiloco21
they both dont' have 35mm~~ the max they have is 30~~=.=....
anyone got a better site?....
BUMP
Old Jan 31, 2007 | 07:20 PM
Jason@Riverside's Avatar
30mm is the largest you are going to find... for 25mm and 30mm you are looking at wheel adapters...
H&R makes 25mm as well as Eibach...
What kind of wheels are you running?!?!
Old Jan 31, 2007 | 07:21 PM
GreenGoblin's Avatar
The goblin resurrection
That is a lot of offset what wheels do you have
Old Jan 31, 2007 | 07:32 PM
ELE's Avatar
ELE
wat is the different between wheel adapter, or wheel spacer?>...<....
my rims 19"X9 with a gay offset 45, HUB 79.5(not sure about this)=.=...IS WRONG...w/e....trying to solve the problem...does it gonna fit into my coupe?....and i found this....is it gonna help?....looking for 1" front and 1.5" rear
http://cgi.ebay.ca/WHEEL-ADAPTERS-SPACERS-5x114-3-INFINITI-NISSAN-1-5_W0QQitemZ320076027285QQihZ011QQcategoryZ42614QQtcZphotoQQcmdZViewItem
Old Jan 31, 2007 | 07:43 PM
redlude97's Avatar
send the wheels back or try and sell them to a sedan owner and take the loss. We already went over this, and no one is going to recommend running spacers that large. The OEM studs are only 25mm long, so you are going to put alot of stress on the studs, and in addition mess up the loading on the wheels. The face of the wheels are going to get pushed too far from the hub and cause a large amount of stress on your suspension. Also, those wheel spacers won't work because they aren't hubcentric
Old Jan 31, 2007 | 08:17 PM
Keith N's Avatar
Here's a link for a Kics 30mm wheel spacer - https://g35driver.com/forums/showthr...m+wheel+spacer. You probably won't be able tell the difference in 5mm. Just bought some Kics 20mm spacers all around, I'm happy with them.
Old Jan 31, 2007 | 08:34 PM
ELE's Avatar
ELE
the question in my mind is if i run 25mm front and 30mm rear, is that' gonna fit?....HUB:79.5 dont' even know wat's that mean...it said on the wheel...., now im thinking about selling my rims=.= just pissing me off....
Old Jan 31, 2007 | 08:37 PM
Calvin's Avatar
Overglorified Altima
yes. sell the wheels and get some with the right offsets
jsimonk
Dec 22, 2023 03:49 PM
paolojericho11
Sep 11, 2015 07:08 AM
tphan
Aug 31, 2015 10:45 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
