6 spd coupe top speed only 140 ??
Old Feb 5, 2007 | 04:41 AM
jadenharrow's Avatar
I took my car to a track, and wanted to reach top speed, well it seemed like when i hit 140 i was limited like my engine had plenty of power but i wasnt getting any more fuel or something
Do we have a limiter at that speed ? Can i remove it ?
(i did a search but only found info on sedans )
Old Feb 5, 2007 | 05:25 AM
aleok's Avatar
yea its the gov limiter, i thought it was around 155ish. yes you can remove it, its a whole package ECU thing. about $800... correct me if i'm wrong..
Old Feb 5, 2007 | 05:39 AM
AAClaire420's Avatar
yeah I wanna remove mine and get a chip....whats the whole process gonna run me normally?
and how hard is it?
Old Feb 5, 2007 | 07:04 AM
Rphillips6487's Avatar
I didnt fool around with any governers or rev limiter and I hit 155-156... dont know what your doing
if you look at some threads about fastest youve every gone youll find most others are around this too
Old Feb 5, 2007 | 08:05 AM
Diamond G35's Avatar
Isn't the top speed achieved in 5th gear, rather than 6th anyway?
Old Feb 5, 2007 | 10:24 AM
IvoryGT's Avatar
the intake valve begins to close around 140, to achieve top speed, it takes a whole lot longer than going from 130-140. A chip will fix this.
Old Feb 5, 2007 | 10:35 AM
b00stedjustin's Avatar
if you aren't short shifting.
Old Feb 5, 2007 | 11:19 AM
jascastan's Avatar
Just get an ECU re-Flash. Most ECU flashes remove the speed limiter and if you have an older G, like an 03 or 04, it raises your redline to 7100 RPM. If you search you can probably find a couple of places that re-flash our ECUs. I had mine done at Altered Atmosphere.
Old Feb 5, 2007 | 11:21 AM
doomsday123's Avatar
How much do the machines cost to reflash the ECU. Seems awful expensive just to get it flashed at a shop.
Calvin's Avatar
Overglorified Altima
isnt it at 155-156 like someone said above?
Old Feb 5, 2007 | 11:50 AM
logik05se's Avatar
i had my car doing 147....
Old Feb 5, 2007 | 11:57 AM
Scootch's Avatar
even tho i drive an auto, i still had my car up to 154mph, and i felt like i could go 160 mph,
but as for the limiter, if u stomp the gas, ur cars comp will limit the flow of the fuel, so i only psuhed it 3/4 of the way to i still got fuel, if u want a quick fix try the technosquare ecu, the elimiate this feature in ur car and up the fuel radio to ur engine and also changes alot of other stuff
the stock ecu sucks cause the harder u hit the gas and higher the rpms are the less fuel goes to ur engine =0(
Old Feb 5, 2007 | 12:23 PM
yah as I previosly stated, I had it at 155-156 and I still had more room to go, for mods I only had a z-tube and K&n filter
Old Feb 5, 2007 | 01:39 PM
Casetay's Avatar
1ClssyG
^Sorry but I don't believe it. I got mine on a downhill slope on the interstate and it wouldn't do over 143ish. I also have a Ztube and plenum spacer.
Old Feb 5, 2007 | 01:40 PM
Casetay's Avatar
1ClssyG
Someone needs to take a pic of their car doing above 150 and I'll believe it haha. I agree with it still has enough to keep it going though. I hate limiters
