Twin Turbo Ideas?
Feb 15, 2007 | 10:45 PM
Hey I just got a slightly used 2006 g35 coupe 5AT. I am wanting to make this car pretty fast. I have thought about many different setups but need some help. I was wondering if some people could give some suggestions, like a built engine setup, twin turbo kit, exhaust, test pipes and an other performance parts you guys can think of. I am looking to generate from 500-550 hp. Or maybe 600+. If you guys could give some ideas that would be great.
Thank You
- Anthony
Reply 0
Feb 15, 2007 | 10:51 PM
your def. looking for FI..id personally go TT to start you off
Reply 0
Feb 15, 2007 | 10:53 PM
Yeah that is what I am looking to do but I can not put that kind of hp out without upgrading internal engine mods. So I was wondering if anyone had a nice custom built engine setup with any other performance mods mixed in.
Reply 0
Feb 15, 2007 | 11:18 PM
Quote: Yeah that is what I am looking to do but I can not put that kind of hp out without upgrading internal engine mods. So I was wondering if anyone had a nice custom built engine setup with any other performance mods mixed in.
I think you'll find the end results are not worth the extra $$$$$
Go TT with nice tune and put out 500 ..then you wont have to go to
crazy wth drivetrain work. go 500+ and expect to pull tranny/rear
and have mr weld come in to tighten her up
Reply 0
Feb 16, 2007 | 01:04 AM
Turbo is probably the way to go, Esp if its your daily driver. If you hit the gas soft and shift early you wont get much boost to your manifold. If you have a supercharger, your practically full boost all the time. and that **** is gunna be loud.
APS is a good choice, out of the box your looking at 9psi
Greddy is about 10.
Reply 0
Also, I would stay around 450 MAX with a stock tranny on an AT, and if you ever do boost it, definitely put a tranny cooler
Strup headers, APS 3" exhaust, and any 2.5 or 3" exhaust will do.
Reply 0
Feb 16, 2007 | 02:22 AM
send your car to vrt
Reply 0
Feb 16, 2007 | 10:24 AM
Quote: Hey I just got a slightly used 2006 g35 coupe 5AT. I am wanting to make this car pretty fast. I have thought about many different setups but need some help. I was wondering if some people could give some suggestions, like a built engine setup, twin turbo kit, exhaust, test pipes and an other performance parts you guys can think of. I am looking to generate from 500-550 hp. Or maybe 600+. If you guys could give some ideas that would be great.
Thank You
- Anthony
if you only want 500 hp you can go an easier single turbo route, but if you want 600+ then you definitely should go TT. There are a number of kits for both turbo setups. Do some searching and you'll find everything you need to know.
Reply 0
