couldn't go pass 3000rpm ?
Old Feb 16, 2007 | 05:27 AM
swong's Avatar
i just got home from shooting pool wit my friend. and he wanteds to check out my G, so i let him take it for a ride. before we took off, i popped the hood and we were just checking it out. Then we took it around the block, but then he notices he couldnt go pass 3000rpm becuase the car started to jerk continuously... so then i got in the drivers seat and turn it off then on again. and it as still doing the same thing. So we pulled over again and i popped the hood and was checking it everything seemed fine so i closed the hood. then everything was ok again... have this ever happened to anyone? i think ima take it in to get it checked out
Old Feb 16, 2007 | 05:30 AM
WaLLy's Avatar
strange...
Old Feb 16, 2007 | 07:07 AM
GTT's Avatar
GTT
G35 Twin Turbo
happend before
Old Feb 16, 2007 | 08:00 AM
delion21's Avatar
I had the same problem once but mines was a little different.
When I would start the the VDC and check engine light wound stay on as well as teh oil light. My car would not rev pass 2k and it sounded like crap. To make it worst it was raining and I had no umbrella.
I got got to make sure I did not have any leaks in any hoses or if any hoses on the CAI came loose but everything checked out to be fine. Restarted the car but got teh same result.
Disconnected battery for 10 min then all was fine.
Took it to the dealer the next day and they replaced the ECU....so I would have it looked at.
Old Feb 16, 2007 | 09:18 AM
Deang35c6's Avatar
sounds like limp mode. Do you have a CAI or recently cleaned and oiled K&N filter?
Old Feb 16, 2007 | 10:24 AM
kidtronix's Avatar
Optional
Sounds like a MAF problem that's been complicated by terrible grammar.
Old Feb 16, 2007 | 01:04 PM
Scootch's Avatar
maybe back gas, alot of those cheaper places have alot of water in the gas and you could have alittle blockage that came loose after driving it a bit more
just an idea, also was it very cold where you are, if so when u start your car from sitting for a few hours or over night in the cold, your car will stutter until she warmes up or you might have hit ur mas plug and it came a bit losse and hwn u closed hood it poped back into place or reconnected from a loose connection
Old Feb 16, 2007 | 01:06 PM
Jtrain's Avatar
Ohh that sucks, MAF is pretty expensive
Old Feb 16, 2007 | 01:08 PM
sahib's Avatar
i think it sounds like the car went into some safe mode cuz the maf sensor might have gone nuts...has hpnd before...wud get it chkd out just in case.
Old Feb 16, 2007 | 01:12 PM
bluegenie's Avatar
Curious what is a MAF and ECU? I'm lost.
Old Feb 16, 2007 | 01:15 PM
Scootch's Avatar
maf = mass air flow sensor
ecu = the cars computer
Old Feb 16, 2007 | 01:16 PM
ModMe's Avatar
MAF = Mass Air Flow sensor, it detects how much air is going into your engine and the temperature. That's how the ECU, Engine Control Unit, decides how much fuel to feed to your engine. With the MAF malfunctioning, the ECU limits the rev to under 3000 so not too much gas is flooding your engine and damaging parts.
Old Feb 16, 2007 | 01:17 PM
bluegenie's Avatar
Oh ok, thanks Scootch!
Old Feb 16, 2007 | 01:18 PM
bluegenie's Avatar
Thanks! Thought I find out just incase I ever incounter the smae problem. Thanks for the info!
