Help, My Backseat Won't Fold Down Anymore
Old Feb 16, 2007 | 03:45 PM
digitalhifinet's Avatar
Exclamation Help, My Backseat Won't Fold Down Anymore
This just happened one day when I folded up my rear seat. The seat release in the trunk is apparently no longer connected to the latch in the cabin. Is there another way to release the latch? I have taken my rear seats out before, but I have always started by folding them down. I would rather avoid seeing the dealer, because I will get a lot of crap about how it was probably my interior mods that caused the problem, although I definitely was not. Any help would be awesome.
Old Feb 16, 2007 | 05:25 PM
GR8TG35's Avatar
There are two ways to release the rear seats...
The first is the plastic pull lever in the trunk
The other if it is still available, should be a red strap that is situated in the interior between the seat back and bottom in the center of the seat section...
If you put your hand in between the two sections and feel around, you should find this red strap.........give it a tug and it should release the seat for you.....
I have an 04, but I'm assuming all the G's have both options for lowering the rear seat.
Old Feb 16, 2007 | 06:17 PM
GreenGoblin's Avatar
The goblin resurrection
never seen the red strap in mine
Old Feb 16, 2007 | 06:34 PM
redlude97's Avatar
The red strap is there, just keep digging around in the crack until you find it, then pull it towards the driver side panels. Most likely your handle got disconnect somewhere around there and you can trace it back and fix the problem without going to the dealer
Old Feb 16, 2007 | 06:36 PM
RBull's Avatar
Rated M
^+1.
The strop is there just tucked between the seat cushion and upper.
Old Feb 16, 2007 | 08:00 PM
DHCrocks's Avatar
once yo do pop it with the red stap, take off the bottom part of the seatback. it should fold up. you need to take out the 2 plastic clips and it's velcro'ed on. then you can see the cable and lever to release the seatback. Mine had come off too, and just pop it back in place and it should work.
Dallsinghjr1
Sep 17, 2023 11:25 AM
g.spot
May 9, 2016 10:54 PM
KallDay86
Jan 8, 2016 12:42 AM
prinny
Nov 22, 2015 11:07 PM
w4kj4k
Oct 2, 2015 07:57 PM
