it wouldnt play my CDs
yeaaa i posted this in the audio tech section but ididnt get any helpful reply. My G doesn't play any burnt cds or regular cds, after i insert the disc, it'll saying READING DISC then it just saids CHECK CD. i also tried burnning the songs in different format but still doesnt work
helppppp
helppppp
Originally Posted by grifter91
Make sure they are CD-r's not CD-rw's. Also brands do make a significant difference. Try using a higher grade of blanks, such as Verbatim or Memorex.
mine does the same thing...it doesnt matter if the cd's r burned or not...i think the cd player just is crapping out. im gonna bring it to the dealer to have it replaced soon.
Your CD player may be a goner. I've had mine replaced twice under warranty, after getting the same problem as you have. Now, it plays commercial CDs, CD-R and CD-RW.
pssh I'm using .01 cd-r's from Fry's and it works like a beaut!
Was the unit playing fine with cd-r's before and break all of the sudden?
Just becareful when you use these cd-r, mine got stuck in their Disk #5, I had to bring to the dealer to replace the whole CD-player. Other than that, my Cd play all kind of CD type. If you can't play any regular CD, then your CD player has a problem, should bring back to the dealer for replacement, it's free replacement and labor under warranty.
Diode Dynamics
Accessories-Vendor
39
Nov 30, 2021 02:28 PM
