Question about the Bat OVERLAYS???
Old Feb 17, 2007 | 04:38 PM
wreckeds2k's Avatar
i just put the opaque black on my 05 coupe and they look blistered.. Is this how they normally turn out or are they usually very slick and smooth??? I havent tried Andrew yet....Just looking for a quicker answer.
Old Feb 17, 2007 | 04:59 PM
fhumphrey04's Avatar
How did you apply them?
My overlay says to use soapy water underneath them, then squeegy out the liquid for the best smoothness.
Old Feb 17, 2007 | 05:15 PM
BadBoy06's Avatar
I've done 2 of his. Try to get that water out or you can use a slight pin needle to pop it (don't worry you wont see that).
Blow dryer also helps to remove. When I did my fronts those lil bubbles vanished on there own when Mr. Sunshine said hello.
The rears were a lil bit more of a challenge because of the curves
Old Feb 17, 2007 | 06:08 PM
sahib's Avatar
from what i've heard your supposed to leave the overlays in the sunlight/heat so they go away...my friend got them done...too bad right wen he did it there was purty mch no sun for like 2mnths...hehehe
Old Feb 17, 2007 | 06:23 PM
Blue_Batmobile's Avatar
Official Sponsor of the Florida G35 Club
sounds like you have moisture trapped underneath! Look here at some application guides:
http://www.scionlife.com/forums/viewtopic.php?t=34653
http://www.scionlife.com/forums/viewtopic.php?t=131312
http://auto.badtziscool.com/howtos/overlays.asp
Bat™
Old Feb 17, 2007 | 06:31 PM
rkesh88's Avatar
bat when are the 07 altima overlays goign to be ready and pictured?
Old Feb 17, 2007 | 08:12 PM
Jtrain's Avatar
The more time you give them, the better they turn out.
The worse job you did, the longer your going to have to wait
Old Feb 18, 2007 | 04:28 PM
Headlights and signal overlays done . Taillights will be ready after Tuesday .
Bat™
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
UT G35
Sep 3, 2015 03:58 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
