Air leak, window seal
Old Dec 2, 2003 | 12:47 PM
bkchang79's Avatar
Does anyone have a air leak sound at freeway speeds (65+) near the rear corner of passenger and driver side window?
2003 G35 Coupe 6mt Diamond Graphite
1992 Jeep Cherokee Blk 5.5 RE lift /w 33s
AIM= bkchang79
Old Dec 2, 2003 | 01:12 PM
Msedanman's Avatar
O.F. Administrator
Re: Air leak, window seal
No air leak here bro. Are you sure the windows are right up and seating properly when the doors are closed?
If the window is adjusted down even slightly, it won't seat that extra 1/4" when the door is closed.
Otherwise the window is out of adjustment, or the weather seal is biotched.
GSM
<font color=red>GSM</font color=red> <font color=black>Silverstone Coupe</font color=black>
Old Dec 2, 2003 | 06:46 PM
theworm's Avatar
Yea, I have a high-pitched whistle at 70+. Subtle but annoying nonetheless. Haven't isolated the location but sounds like the rear upper portion of the D side. I can't SEE anything out of the ordinary w/r/t the seal or molding. I'll probably experiment with some electrical tape to isolate the exact spot before taking it in.
Old Dec 3, 2003 | 09:09 PM
Bluestreak's Avatar
Me too- noticed it just recently (I've had the 6M/T since February), and only above 70MPH. Figured I'd mention it when it goes in for the next oil change. And yes, my windows are all the way up. Interestingly, it may have started after I had the window rollers replaced (to stop that ugly grease streak problem).
Old Dec 4, 2003 | 09:59 PM
booger's Avatar
I didnt have an air leak..but water got in the top corner of drivers window. I took it to dealer and they adjusted the door and now no leak...take it it in and Im sure they can fix it
Old Feb 18, 2004 | 08:49 PM
theworm's Avatar
Any follow-ups or successes with fixing this one. I'm back from the dealer's first try and it was unsuccessful. They replaced a part of the molding/seal that's actually attached to the door where the mirror's attached (the triangular piece @ the front). No effect.
I still think it's the entire "upside down U" molding or a slightly misadjusted window (not going up quite enough). The problem w/my electrical tape experiment is that although I can alter or even eliminate (mostly) the whistle, I don't know if the cause is the seal or a slightly-low window, since the tape would bridge the gap.
Thoughts, successes and part numbers would be great. I'm sure my dealer will eventually find it, but a headstart always helps
Old Dec 7, 2010 | 01:08 PM
DT35G's Avatar
Bump for an answer to this question. My air leak noise is starting to really **** me off. Passenger side the worst! Dont know if I should replace the mouldings or what?
Old Dec 7, 2010 | 01:19 PM
G35SedanGrn's Avatar
oh my dont remind me, i've had the leak for as long as i can remember its anoying and the dealer wont fix it.
Old Dec 7, 2010 | 02:29 PM
TannerG's Avatar
I'm sure it's pretty common to have air leakage when you don't have a frame around your window. I've had a couple cars with out window frames and they've all leaked.
DT35G's Avatar
It sucks, It doesnt drive off the lot that way so there must be a fix for it. If it wasnt so damn cold out i would go outside and start trying to figure it out myself
Old Dec 7, 2010 | 04:25 PM
parhamm1's Avatar
It's either adjusting the window or replacing the black weather stripping. I have the same issue and I've been dealing with it forever. One of these weekends I'll get around to ripping the door apart and adjusting the window to see if that will fix it.
Old Dec 7, 2010 | 05:11 PM
smiLee.'s Avatar
In for an answer as well, this just started happening to me after i installed my new gialla grill, could it possibly be coming from that? After my car is at around 40-50mph I hear a whistle.
Old Dec 7, 2010 | 09:36 PM
VQ Johnny's Avatar
I had this issue in my Maxima and I used some type of foam weather stripping behind the OEM molding and stopped the noise, I'm gonna try it out and see if it will work with the rimless doors of the G this weekend. Hopefully it works, IIRC when I priced a new molding it was over $100, so hopefully this will be a cheap permanent fix.
Old Dec 7, 2010 | 10:01 PM
Moe'sG's Avatar
I've had the same issue for MONTHS!!!! fix to this is bumping up the stereo lol but i'll probably take in next at the Stealership
Old Dec 7, 2010 | 11:33 PM
Javi04's Avatar
This is a common issue. I got use to the sound, plus I usually have the stereo up. I start hearing it when I drive above 60.
