Axle click on 2006 G35 Coupe
Old Mar 6, 2007 | 11:38 AM
  #31
Gbiker's Avatar
Originally Posted by vhtran
shiet, i had that problem b4 ... Had it fixed under warranty, as soon as it off warranty, it happened again (annoyed as hell). Kinda lazy to get it fix, after few months the issue just gone itself. Driving still normal, hope it won't come back.
Your really lucky in the fact that your goes away. Hopefully for u it wont come back!! GOOD LUCK BROTHEr!
Old Mar 6, 2007 | 07:00 PM
  #32
decoy's Avatar
I have an 03 and had it fixed more than 4 times, and the clicking comes back within a week.
Old Mar 7, 2007 | 01:30 PM
  #33
Kuneff's Avatar
Does anyone have a link to instructions on pulling the rear axle's out? I am thinking about doing this myself tonight before I take the car in for service tomorrow. I have 47k miles on my 03.
I have some issues with the rear suspension now. passenger side tire is wore completely to threads on the inside. Maybe its alignment, but Im not sure. I just dont want to get raped, and I figure if I do it myself maybe it will be done right.
Old Mar 7, 2007 | 01:50 PM
  #34
dudeimjohn's Avatar
i'm kind of worried. what exactly is this clicking noise? is it loud or subtle? is this on the manual or auto?
Old Mar 7, 2007 | 02:05 PM
  #35
vhtran's Avatar
Go to Nissan/Infiniti
https://www.nissan-techinfo.com/infiniti/
Old Mar 7, 2007 | 02:30 PM
  #36
twin_snails's Avatar
Originally Posted by dan61177
TSB = Technical Service Bullitan and yes there is a TSB on this problem. It is not only in the '06s. My '04 was doing the same thing and I took it in and told them there was a clicking. They said they knew exactly what the problem was and that there was a TSB on it. Took them 30 min to do and I waited in the lobby and ate my free donuts and sodas.
My '04 Coupe had this issue and I was one of the first ones apparently because they replaced the manual trans in my car as well as did some reworking (grease I assume) to the rear axles. I haven't had the problem since.
Old Oct 19, 2007 | 10:57 PM
  #37
DefJux921's Avatar
i know this is an old thread now but i wanted to report back now thats been more than half a year since having it fixed - the clicking has not returned..
Old Oct 19, 2007 | 10:59 PM
  #38
O HELLA OEM's Avatar
yea i get that clicking sometimes then it goes away come back blah blah
Old Oct 20, 2007 | 03:44 AM
  #39
drpthemc's Avatar
just curious... what does the rear axle click actually sound like?.. is it a noise u hear when u accelerate?.. brake?.. turn?.. start the car?..
i have an '07 coupe.. do any '07 owners have this problem?.. or has it been fixed for the '07 models?...
thanks for your replies!..
Old Oct 20, 2007 | 03:50 AM
  #40
izmir41500's Avatar
G35driver Addict
there is either a loud click or tick from one or both sides of the rear when you accelerate from a stop. you can't miss it. roll down your windows and start acclerating from a stop then there will be a loud click.
Old Oct 20, 2007 | 09:01 AM
  #41
05GCOUPE6MT's Avatar
DAM Does Infiniti FIX anything. You would think that by 2006 this would NOT be an issue. I guess 4 years is not enough time. At least they have a new GEN out. LOL.
Old Oct 20, 2007 | 01:30 PM
  #42
DefJux921's Avatar
drive next to a wall or in a parking garage with your windows down and radio off... when you accelerate from a stop its pretty obvious... on my car it was only on the passenger side but it can be on both sides.
and yah... wtf... i was kinda upset that on my 06 it had that problem... i used to think its best to always wait until at least the 2nd year of a car so they can fix the probs... at least the dealer was able to fix it so im over it... it's such a great car and that fact far outweights the few annoyances i have with it.
Old Oct 22, 2007 | 03:34 AM
  #43
Gday's Avatar
I have an 06 and my rear axle bolt had to be re-torqued because it got loose. Or it was loose out of the factory. It basically caused a "popping" noise every time i hit a bump or drive on uneven pavement or up and down a driveway.
Old Oct 22, 2007 | 05:09 PM
  #44
SukaZenki's Avatar
If you've gotten the TSB done on your Rear Axle and the problem which is not a Clicking sound but more like a Clunk sound at slow speed going over bumps; then have you End Link Bushings on your Sway Bar replaced. Don't just get it tightened which the dealer always will do, get it replaced. Worn bushings don't get tightened; they get replaced. That should atleast fix most/all/some of you guys reporting this sound from the Rear Axle.
Old Oct 23, 2007 | 02:39 AM
  #45
g35ctuner's Avatar
mine had it too. so stupid, so simple, so annoying. i can't wait to see the g37 guys posting about a mysterious clicking sound......
