Using a floor jack?
Old Mar 3, 2007 | 12:41 AM
2EFNFAST's Avatar
Using a floor jack?
Where are the best points to use a floor jack on the coupe - typical differential housing and front cross-member? Thaniks.
Old Mar 3, 2007 | 12:56 AM
gary c's Avatar
Simple answer..............
Check the owners manual, it shows exactly where to jack up your GC.
Old Mar 3, 2007 | 01:35 AM
StreetChase's Avatar
I generally just use the fatory jack points. put the floor jack right on the notches and your good to go
Old Mar 3, 2007 | 02:35 AM
2EFNFAST's Avatar
if by factory jack points you mean those reinforced points where the scissor jack goes, i've always been told that's it's a serious no-no to use a floor jack at those locations.
i looked; couldn't find anything (other than for scissor jack)
Old Mar 3, 2007 | 06:25 AM
pop099's Avatar
The only downside of using the frame rails (the sides of the car where the scissor jack goes) with a floor jack is that if you don't have a groove to catch the rail, it bends some.
I've been using frame rails to jack cars up for a couple of years now.
Or you could just be super cool and use the oil pan.
Old Mar 3, 2007 | 09:49 AM
LT1 SS's Avatar
Yup the diff housing and cross member.
https://g35driver.com/forums/attachm...7&d=1171996558
Old Mar 3, 2007 | 12:38 PM
jdmeg21's Avatar
yeah I used the side notchs and bent them. so I have to get a low profile jack to get to the cross member.
Old Mar 3, 2007 | 01:15 PM
2EFNFAST's Avatar
Awesome; thanks a bunch.
Old Mar 3, 2007 | 01:46 PM
G-MENTED's Avatar
same here.
Old Mar 3, 2007 | 02:37 PM
kidtronix's Avatar
Optional
First, use the SEARCH function. Someone posted a JPG of jack points just weeks ago.
Old Mar 3, 2007 | 03:01 PM
Meatshackle's Avatar
Deep Sea Moderator
I've used the notches every time I've put mine up. I set the jack up about 5 inches to the rear of them so I can put the jackstands right on them. I've had my car on jackstands for over a week like that, more than once, and haven't bent the rails.
Old Mar 3, 2007 | 03:33 PM
2EFNFAST's Avatar
Just because you havn't "won" a game of russian roullette doesn't mean you'll never win one
Old Mar 3, 2007 | 03:41 PM
i put a block of wood on the jack. ive never had a problem
Old Mar 3, 2007 | 06:47 PM
Rphillips6487's Avatar
search this man, i just did a thread on this exact thing and recieved ample help
AL8782
Oct 3, 2015 10:26 AM
Jeff T
Sep 30, 2015 02:00 PM
Hogbone
Sep 28, 2015 06:44 PM
