Power Braking
Old Dec 6, 2003 | 12:18 AM
Nforce1's Avatar
Power Braking
How bad is this for your brakes and engine?? Is it somthing that I should be concerned about doing?
Old Dec 6, 2003 | 12:51 AM
d3g's Avatar
d3g
Re: Power Braking
I read somewhere that you shouldnt rev the RPM's past 2k while power braking. It said it could damage the stall converter. I would just hold the brakes and rev the RPM's up to about 1.5k but not to wheel spin. Just for a good launch. I dont think it would hurt the brakes as long as the wheels dont spin while holding the brakes. Check out this video (1mb) I have of a power brake lauch. It shows the gauges. http://home.earthlink.net/~digitalus...G35_01_1mb.wmv
www.corevoltage.com
Stillen Box | Fallsgate Amp | Projection Fogs
Old Dec 6, 2003 | 10:12 AM
Balzac72's Avatar
G SQUAD
Re: Power Braking
Is that what people with automatic tranny's do? HA!
03.5 6spd DG/G aero pk/kit + Hyper Grounded
FX35 Blk/Brick Tech pkg
He who makes a beast of himself gets rid of the pain of being a man.
Old Dec 6, 2003 | 10:24 AM
blackonblackG's Avatar
Re: Power Braking
in the video did you hit the rev limiter in 1st?
Old Dec 6, 2003 | 11:56 AM
G35Gnome's Avatar
Re: Power Braking
"Is that what people with automatic tranny's do? HA!"
is dropping the clutch what people with MTs do ? HA!
Yea I noticed you hit the rev limiter too.
Crawford Plenum / Z tube + Stillen Hi-Flow / Borla Dual Exhaust / Stillen Xdrilled+Stotted Rotors
Best 1/4 mile 14.371 @ 100.29, 60ft 2.347
Old Dec 6, 2003 | 12:19 PM
Balzac72's Avatar
G SQUAD
Re: Power Braking
Manual transmission cars are able to handle dropping the clutch long term. You cannot say the same thing about AT's. And no, I don't "drop" the clutch at a high enough rpm that it can't catch or slips.
Old Dec 6, 2003 | 03:26 PM
Aldo420's Avatar
Re: Power Braking
droping the clutch and power breaking is bad for your cars...
but us ATers need to power break for a good launch...
Old Dec 6, 2003 | 05:47 PM
d3g's Avatar
d3g
Re: Power Braking
Yea I hit the limiter in 1st. SHUTUP! hehe jk man thats one of the downsides with the 5AT is the time it takes to switch after you upshift. Sometimes it's very accurate while other times... well you see. I hardley ever hit the limiter but it happens. I usually do an ECU reset after i do thought just incase it goes into some type of safe mode with the air/fuel mixture or something.
www.corevoltage.com
Old Dec 7, 2003 | 12:30 AM
ozracer01's Avatar
Re: Power Braking
Hmm...Your shifting from 2nd to 3rd at about 6900 rpm....now i don't race too much in my G, nor have i taken it past 6k rpms....but is that safe to do?
04 DG Coupe, Prem Package, Aero
Old Dec 7, 2003 | 01:50 AM
DaveO's Avatar
Re: Power Braking
High rpm or repeated power braking of a stock torque converter can lead to severe damage. Aftermarket performance TCs are typically furnace brazed, have hardened components and improved thrust surfaces/bearings/etc. to allow for this practice.
DaveO
2003 G35 Sedan - DP / Willow / AT / Premium / Sport
Z Engine Cover & Air Duct / Stillen CAI
GG 7-Wire H-G Kit / TechnoSquare ECU
Street Edge TC / Stillen Exhaust System
Old Dec 7, 2003 | 03:30 PM
JDMan's Avatar
Re: Power Braking
Power braking at any rpm is worse on the transmission than not power braking. I only do it just enough to "wake up" the engine when I'm running for times, which is usually barely over 1000. I think you can get away with around 2600. But that's still bad for the car, and if you do it at every stoplight, you will unquestionably cut huge chunks from the life of your transmission. I would save it for "special occassions" only. Let those Hondas go.
-Jack
Obsidian '03 G35 Sports Coupe
Titanium '03 MX-5 Shinsen #532
Old Dec 7, 2003 | 08:04 PM
KAHBOOM's Avatar
Re: Power Braking
I haven't had to power brake yet... the car already has enough torque to move off the line with ease. The AT in this car is a heavy duty trannt. The same as in the Q.
5AT- premiumpackage /performance package/ K&N
Old Dec 7, 2003 | 10:14 PM
DaveO's Avatar
Re: Power Braking
------- M/T --- A/T
1st - 3.794 - 3.540
2nd - 2.324 - 2.264
3rd - 1.624 - 1.472
4th - 1.271 - 1.000
5th - 1.000 - 0.834
6th - 0.794 - N/A
Reverse - 3.446 - 2.370
Rear end - 3.538 - 3.357
DaveO
Old Dec 7, 2003 | 10:44 PM
uheenada's Avatar
Re: Power Braking
umm.. i'm no expert on gear ratios.. can you explain how much differences are those?? looks like MT is little bit taller but not much... and what's rear end?? thanks...
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
cmesidewayz
Sep 29, 2015 09:28 PM
gatorglaze
Sep 10, 2015 12:03 PM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
miata007
Aug 17, 2015 04:36 PM
