sunroof trim
Old Mar 8, 2007 | 07:38 PM
flyt89's Avatar
sunroof trim
i just bought an 05 coupe today and noticed that the trim around the sunroof is not staying. i told the dealer to fix it when i bought it, but they didnt do anything. any suggestions maybe glue or something? Thanks
Old Mar 8, 2007 | 07:44 PM
chrispyy's Avatar
^^ i want to know this also!
Old Mar 8, 2007 | 07:51 PM
GGG Ya's Avatar
are you talking about the visor or the trim around the opening in the interior?
Old Mar 8, 2007 | 08:21 PM
flyt89's Avatar
the trim around the opening in the interior. around the edges
Old Mar 8, 2007 | 08:26 PM
misSxhuStLer's Avatar
the same thing happened to the trim around my sunroof, in the interior. i took it to the dealer and they replaced the entire part with a new one.
Old Mar 8, 2007 | 08:51 PM
flyt89's Avatar
im going to the service department tomorrow to pick up an extra key that they owe me. Do you think that they could replace the whole trim on the spot or do you think i need to setup an appointment? thanks
Old Mar 8, 2007 | 09:19 PM
icab's Avatar
Same here. They must have used some ****ty glue. I'm sure you can just have them glue it back. If you ask for them to replace it, then you will need to have an appt to have them look at it. Then they will have to order the part and you will have to come back a few days later. PITA.
Old Mar 8, 2007 | 09:30 PM
the dealer had the part in stock when i took my car in, so they replaced it that day. if not, i'm sure they'll order it and have you come back.
Old Mar 8, 2007 | 09:51 PM
BadBoy06's Avatar
simple epoxy glue will do the trick in a few minutes
Old Mar 8, 2007 | 10:07 PM
flyt89's Avatar
for some reason my trim is not only loose, but where it is loose it has a sharp bend in it. so even if i glued it myself the bend would just pop it off again. anyone else have this?
Old Mar 8, 2007 | 10:57 PM
chrispyy's Avatar
^^ same here man i have the same thing as you
Old Mar 8, 2007 | 10:58 PM
chrispyy's Avatar
how much do those things run for anyways
Old Mar 9, 2007 | 12:49 AM
G STACKS's Avatar
wheres the pics?
Old Mar 9, 2007 | 08:40 AM
lekker_droom's Avatar
both of my Gs have hace the lose trim around the sunroof too. Is it a mistake? I figured thats just how they were made to be...
Old Mar 9, 2007 | 08:51 AM
g35brandon's Avatar
thought I was the only one...
