Urgent: Need help..how to adjust clutch freeplay?
Old Mar 13, 2007 | 02:21 AM
cloud's Avatar
This is not the same as the engagement point adjustment DIY.
My clutch has ZERO freeplay after it has been installed.
It starts slipping the moment you begin to depress the clutch. This will most likely cause premature wear...
The manual states that it absolutely has to have 10 - 15mm of freeplay or there will be premature wear.
How do I adjust this freeplay? I want to add freeplay.
Old Mar 13, 2007 | 10:04 AM
g35rcr's Avatar
go search there is a sticky...there is a bolt you have to loosen on the clutch pedal arm, then turn the bolt
Old Mar 13, 2007 | 11:47 AM
cloud's Avatar
My clutch pedal lowers itself in the morning. I have to pull it up with my feet and pump it a few times before it returns to its original position... what's wrong?
Old Mar 13, 2007 | 01:37 PM
SejinxChoujin's Avatar
you probably need to replace your master/slave cylinder.
Old Mar 13, 2007 | 01:51 PM
V35 Skyline GT's Avatar
6MT Coupe
Or sounds like the clutch hydraulic system might need bleeding.
You just got that ORC clutch done, right?
Got something for you that might help, PM sent
Old Mar 13, 2007 | 02:36 PM
BadBoy06's Avatar
bleeding/refill maybe?
Old Mar 13, 2007 | 07:16 PM
GreenGoblin's Avatar
The goblin resurrection
ya sounds like you have some air in the line
Old Mar 14, 2007 | 10:01 AM
or you need to replace your master/slave cylinders. (like i just did cus bleeeding the line didnt work)
Old Mar 14, 2007 | 02:44 PM
cloud's Avatar
btw anyone know how many bottles of clutch line fluid do i need for a complete flush/bleed?
Old Mar 15, 2007 | 09:47 AM
1 should be more than enough. and its gonna be brake fluid.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
Fox843
Nov 7, 2015 05:43 PM
AL8782
Oct 3, 2015 10:26 AM
master111
Sep 25, 2015 08:32 PM
