Heres the pics of my spacer oil spil
Old Mar 14, 2007 | 02:19 PM
gary c's Avatar
Oil or Glue........?
There's a whole bunch of diffrence between oil and glue......ya think? Oil
could have been picked up on your fingers but glue would have made that
somewhat difficult.........dooo.
Old Mar 14, 2007 | 02:49 PM
speedgeek's Avatar
If there was a gasket on top shouldn’t you have 2 gasket tabs sticking out from the front of the plenum?
look to the right on the second gold plenum bolt up front
2 TABS
You have one TAB
Old Mar 14, 2007 | 03:23 PM
BadBoy06's Avatar
Originally Posted by mastarip
i just took the upper plenium off and there WAS a gasket on top, i probably forgot since it was so long ago. But then i called motordyne and he said its a silicone based adhesive that is used to bond spacer to gasket and gasket to upper plenium. He said it melts off from gasket. That makes sense because if it was oil it would be a liquid substance, but that yellowish thing is like rubber/sillicone like the rubber thing thats stuck to papers sometime. so its all good. Thx for the help .
glad it worked out for ya
Old Mar 14, 2007 | 05:09 PM
MastaRip's Avatar
im sure theres a gasket there man, i dont know when u installed your spacer but the guy i spoke to said they have new gaskets now with less adhesive, because before there was too much residue, the gasket i have is black, i guess it only has 1 tab, thats the way it is.
jsimonk
Dec 22, 2023 03:49 PM
skippyG
Jan 25, 2016 01:18 PM
linedr89
Aug 17, 2015 05:11 PM
EPG35
Aug 16, 2015 04:52 PM
