ASAP wire routing (hood <-> driver side)
Old Dec 10, 2003 | 09:38 AM
ericinmia's Avatar
I am attempting this now, and need help!!! please!
How would i go about routing wire from the inside of the drivers side of the cabin to the engine compartment under the hood!
Anyone have any suggestions, and a couple details!
Thanks,
-Eric
'03.5 Silver/Black | Prem | Perf | Aero | Stillen Hi-Flow | Z -Tube | Grounding Kit | Nismo Oil/Radiator Caps | Solid Allum Pedals | Diamond Matts | Tints | Valentine1 | Hide-Away License Plate!
Old Dec 10, 2003 | 10:17 AM
g35mt's Avatar
Re: ASAP wire routing (hood <-> driver side)
depending on how big the wire is, you might have to drill a hole thru the wall. that is what i had to do when i install the edfc.
g35mt
Old Dec 10, 2003 | 10:52 AM
Meatshackle's Avatar
Deep Sea Moderator
I went through the wire harness boot near the passenger corner of the hood. It's right by the battery and drops to the passenger kick panel. From there you can go behind the console along the floor. I ran 4 gauge wire so I had to cut the boot. If you do this you MUST re-seal with some silicone or another waterproof sealant. If you don't you will get water inside the car when you wash or when it rains.
Russ
Black w/willow, 6MT Coupe, nav, aero, V1, PS2, & TVs all up in the headrests.
Jax, FL
mbe093
Lights
Oct 2, 2016 11:09 PM
Ludz
Lights
Mar 28, 2016 02:06 AM
lemmy999
Jul 25, 2015 12:13 PM
attarday
Jul 15, 2015 04:03 PM
