shift knob removal
Mar 18, 2007 | 06:20 AM
no bitching wrong forum i searched and only came across 03-04. im trying to put on my new (used) shifter but i cant find a DIY? and i dont know what im doing so should i just have someone do it and if so who the dealer?
P.S. can i get a few post befor you move it to interior please?
thank you!!
Reply 0
Mar 18, 2007 | 06:38 AM
hmm.. all you have to do is turn it counter clock wise...
Reply 0
Mar 18, 2007 | 06:58 AM
dude it's the easiest mod by far, as what cchao said, hold the **** with both of your hands, and try to make it not moving around if it's a manual, and just use some muscles to twist it counter clock wise, once it's starting to turn, just keep unscrewing, everything will make sense once you give it a try, just got back from the club, something I said might not make sense.....so just do it!
Reply 0
Mar 18, 2007 | 11:07 AM
not as easy as turning it counter clockwise!!!
I'm assuming you have a manual. I just did this mod last month on my 05. Its conceptually easy but hard as hell to do if your shift **** is on as tight as mine was. Be very couscous if you dont want to damage or bend your shifter. You need to pull up the piece of the center console that the **** sits in (it is a clip-on piece) to get access to the shifter. Use a vise grip to hold the bottom of it so it doesnt turn and get damaged. Use another pair of vise grip to turn the **** counter clockwise (using clothe to protect the **** and shifter). If you can get another person to help you, should be doable. The dealer will probably charge an arm and a leg.
Reply 0
Mar 18, 2007 | 11:15 AM
^do you think you really need the 2nd vice grip on the bottom if it is a 6mt coupe?
Reply 0
Mar 18, 2007 | 11:40 AM
Quote: Mine wasn't hard to remove at all... Maybe you guys are just a bunch of wussies
maybe your lock tite was weak
Reply 0
Mar 18, 2007 | 05:33 PM
anyone else use a vice grip to secure the bottom while removing their shift ****??
Reply 0
Mar 18, 2007 | 05:42 PM
Quote: anyone else use a vice grip to secure the bottom while removing their shift ****??
I did, I wasn't really sure if not using one would cause any harm to it, but I figured it's always better to be over precautious. Better safe than sorry.
Reply 0
Mar 18, 2007 | 05:44 PM
alright, sounds good, thanks
Reply 0
Mar 18, 2007 | 05:47 PM
Quote: I did, I wasn't really sure if not using one would cause any harm to it, but I figured it's always better to be over precautious. Better safe than sorry.
I hear that!
Reply 0
Mar 18, 2007 | 06:17 PM
Quote: I'm assuming you have a manual. I just did this mod last month on my 05. Its conceptually easy but hard as hell to do if your shift **** is on as tight as mine was. Be very couscous if you dont want to damage or bend your shifter. You need to pull up the piece of the center console that the **** sits in (it is a clip-on piece) to get access to the shifter. Use a vise grip to hold the bottom of it so it doesnt turn and get damaged. Use another pair of vise grip to turn the **** counter clockwise (using clothe to protect the **** and shifter). If you can get another person to help you, should be doable. The dealer will probably charge an arm and a leg.
i do have a manual 05. its on tight i could not get it. the peice of center console that the **** sits in. do you just pull up or use a screwdriver? and does it just snap back in place?
Reply 0
Mar 18, 2007 | 06:35 PM
^^yes, it will snap back in place
Reply 0
Mar 18, 2007 | 06:36 PM
what im wondering about is the twisting off/on of the shift ****.
I used a vice grip to get it both on and off...
did I do damage to my transmission by not having another vice grip on the bottom?
Reply 0
Mar 18, 2007 | 06:37 PM
Quote: ^^yes, it will snap back in place
do i use a screwdriver?
Reply 0
Mar 18, 2007 | 06:38 PM
Quote: what im wondering about is the twisting off/on of the shift ****.
well did u feel anything or hear anything brake
Reply 0
