Curious about beeping noise
Old Mar 25, 2007 | 02:43 PM
DieselCasa's Avatar
DCASA
When you first start your car, probably most cars a soft beep about 4 or 5 times occurs then it stops. No warning lights, not a problem just a noise that goes off everytime you first start your car... it goes:
beep.............beep.............beep............ ...beeep...........beep
Its a simple sound you have heard for years but whats the meaning of it? anyone know?
Old Mar 25, 2007 | 02:47 PM
Bigd2k6's Avatar
it means you need to fasten your seatbelt. try starting the car with your belt on and it won't go off.
Old Mar 25, 2007 | 02:53 PM
AAClaire420's Avatar
mine doesnt beep I dont think
Old Mar 25, 2007 | 03:06 PM
ndlive's Avatar
yea i think it's the seatbelt too. i usually turn the key until it starts beeping, then put my seatbelt on, then the beeping stops. if you don't put the seatbelt on it stops after like 5 beeps, i think.
btw, is waiting for the car to "warm up" (putting the ignition on "on" position for a few sec rather than firing her up immediately after putting the key in) really necessary?
Old Mar 25, 2007 | 04:13 PM
L Tuner's Avatar
It's not really necessary, it just primes the engine fully before a start is initiated. But the car was designed to prime just enough without leaving it on the 'on' position because almost everyone just turns the key all the way once they get in.
Old Mar 25, 2007 | 06:19 PM
Rphillips6487's Avatar
seatbelt ftw
Old Mar 25, 2007 | 06:38 PM
GGG Ya's Avatar
is the door open when you start it up?
Old Mar 25, 2007 | 07:44 PM
Msedanman's Avatar
O.F. Administrator
I've heard that beep in all my INfiniti's and I assume that it's to do with the 'puter booting up.
C.
Old Mar 26, 2007 | 12:01 AM
wilksoner's Avatar
check ur trunk make sure its closed mines done that b4 when the trunk was open if u have nav turn it on if its that it will tell u when u start it
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
